Seria data manipulation/capture help
k_man
PostPosted: Wed Jul 11, 2007 4:20 am    Post subject: Seria data manipulation/capture help Reply with quote
I am using these Bluetooth units.
http://www.sparkfun.com/commerce/product_info.php?products_id=582
AT Command datasheet
http://www.sparkfun.com/datasheets/RF/BlueRadios_ATMP_Commands_Rev_3.5.2.1.4.0.pdf
I wasn't sure what serarch terms to use so could not do my usual exhaustive search before asking Smile
Basically I want to capture each address the query returns.
I can grab the first one but don't know the most efficient way to grab the rest.
And prehaps a timeout routine.
The serial transaction looks like this
19:02:56.87 [TX] - atdi,5,00000000<cr>
19:02:57.04 [RX] - <cr><lf>
OK<cr><lf>
<cr><lf>
000A3A66C0E6,00320104<cr><lf>
<cr><lf>
000A3A66C0E7,00320104<cr><lf>
<cr><lf>
000A3A66C0E8,00320104<cr><lf>
<cr><lf>
000A3A66C0E9,00320104<cr><lf>
<cr><lf>
DONE<cr><lf>
<cr><lf>
19:03:37.38 [TX] - ATRRN,000A3A66C0E6<cr>
19:03:37.52 [RX] - <cr><lf>
OK<cr><lf>
<cr><lf>
WORKSHOP<cr><lf>
<cr><lf>
The program I have so far.
It is not pretty so be gentle Smile
$regfile = "attiny2313.dat"
$crystal = 8000000
$baud = 9600
$hwstack = 32
$swstack = 32
$framesize = 32
'     Rst |1xx0| Vcc
'Rxd  Pd0 |2 x9| Pb7
'txd  Pd1 |3 x8| Pb6
'     Pa1 |4?x7| Pb5
'Upd  Pa0 |5? 6| Pb4
'     Pd2 |6  5| Pb3
'     Pd3 |7  4| Pb2
'     Pd4 |8  3| Pb1
'     Pd5 |9  2| Pb0
'     Gnd |0x 1| Pd6
Config Porta.0 = Output
Upd Alias Porta.0
Dim Var_counter1 As Byte
Dim Var_serial_chr As Byte
Dim Var_input_string_1 As String * 13
Dim Var_done As Byte
Dim Var_friendly_name_1 As String * 4
Const Con_serial_chr_stop_1 = 44
'comma ,
Const Con_serial_chr_cr = 13
'CR
Const Con_serial_chr_lf = 10
'LF
Const Con_start_delay = 2
's
Const Con_string_length = 13
's
Main:
      Wait Con_start_delay
Discover:
      Var_input_string_1 = ""
      Print "ATDI,1,00000000"
   Gosub Sub_wait_for_crlf
Read_addresse1:
      Var_serial_chr = Waitkey()
   If Var_serial_chr = Con_serial_chr_stop_1 Then Goto Read_addresse1_end
   If Var_serial_chr = Con_serial_chr_cr Then Goto Read_addresse1_end
'checks for comma - or cr when no devices found
      Var_input_string_1 = Var_input_string_1 + Chr(var_serial_chr)
   Goto Read_addresse1
Read_addresse1_end:
   If Var_serial_chr = Con_serial_chr_cr Then Goto Main
      Wait 8
Get_friendly_names:
      Print "atrrn," ; Var_input_string_1
   For Var_counter1 = 1 To 4
'Only store first 4 characters of name
   Next Var_counter1
      Print "Friendly_name=" ; Var_input_string_1
   Wait 5
   Goto Main
'-----------Subs
Sub_wait_for_crlf:
Wait_for_cr:
   If Var_serial_chr = Con_serial_chr_cr Then Goto Wait_for_cr_end
   Goto Wait_for_cr
Wait_for_cr_end:
Wait_for_lf:
   If Var_serial_chr = Con_serial_chr_lf Then Goto Wait_for_lf_end
   Goto Wait_for_cr
Wait_for_lf_end:
