Need help with person counter project
Post new topic   Reply to topic    www.mcselec.com Forum Index -> BASCOM-8051
Tripwire
PostPosted: Sun Jun 17, 2007 2:27 pm    Post subject: Need help with person counter project Reply with quote
Hi guys i'm doing a project for school and i need to make a person counter. Now i have wrote the most of the program needed for te project.
The only thing i need now is to write a program that transfers the numbers from the counter to my 7 segment diplays and in between there are 74hc4094 as datashifters registers. Now i learned to write bascom in a month so i don't know much about how to write most things. I heard i needed to write an array or something but i don't know how to start Sad. Can someone plz help me a bit to start creating an array for my project?
here's my program (i use an 89c2051 uc btw)
Dim Bteller As Byte
Dim Bingave As Byte
Bteller = 00
P1.5 = 1
P1.7 = 0
P1.6 = 0
If P1.7 = 1 And P1.6 = 0 Then
Bteller = Bteller + 1
Print "persoon in" ; Bteller
Waitms 50
P1.5 = 0
Waitms 10
If P1.6 = 1 And P1.7 = 0 Then
Bteller = Bteller - 1
If Bteller = 255 Then
Bteller = 0
Print "person out " ; Bteller
Waitms 50
P1.5 = 0
Waitms 10
Gianni
PostPosted: Mon Jun 18, 2007 8:19 am    Post subject: Reply with quote
With a single 4094 you can count until 99; simply use makebcd and shiftout statement.
Do not forget to limit your counter to 99.
Regards
Tripwire
PostPosted: Mon Jun 18, 2007 10:23 am    Post subject: Reply with quote
can you give me an example, how to use makebcd and shiftout statements? because the examples in bascom are a bit unclear on how it works. We used 2 4094 btw.
Gianni
PostPosted: Mon Jun 18, 2007 2:01 pm    Post subject: Reply with quote
Makebcd works from 0 to 99 decimal
To convert number greater then 99 a different approach is necessary.
I do not remember how the 4094 clock works;
eventually try shiftout Datapin,Clockpin,ones,4
Regards
dim Tmp1       as byte
dim Tmp2       as byte
dim hundreds   as byte
dim tens       as byte
dim ones       as byte
dim value      as byte
Datapin  alias P1.7     'serial data input
Clockpin alias P1.6
Latch    alias P1.5        '4094 latch enable
   latch = 0
   datapin = 0
   clockpin = 0
   do
      input "value ",value
      Tmp1 = value
      hundreds = Tmp1 / 100
      Tmp2 = hundreds * 100
      Tmp1 = Tmp1 - Tmp2
      tens = Tmp1 / 10
      Tmp2 = tens * 10
      ones = Tmp1 - Tmp2
      print hundreds;tens;ones;" = "; value
      shiftout Datapin,Clockpin,ones,3
      shiftout Datapin,Clockpin,tens,3
      shiftout Datapin,Clockpin,hundreds,3
      latch = 1
      nop            'update 4094 output
      nop
      latch = 0
   loop
Tripwire
PostPosted: Mon Jun 18, 2007 2:49 pm    Post subject: Reply with quote
thx man! but i only need to count to 99 so if you can give me an example of makebcd then i can get to work!!
Gianni
PostPosted: Tue Jun 19, 2007 7:30 am    Post subject: Reply with quote
I suppose you do not use a bcd to 7 segment decoder but directly drive the display with the 4094.
Is that right ?
Tripwire
PostPosted: Tue Jun 19, 2007 8:01 am    Post subject: Reply with quote
Hey here is a link to our schematic of the counter. We don't use a decoder like you said.
u4 and u5 are the 7 segment display's
Gianni
PostPosted: Tue Jun 19, 2007 9:05 am    Post subject: Reply with quote
Ok!
Try this.
      Tmp1 = makebcd(value)
      Tmp1 = Tmp1 and 15
      Tmp1 = lookup(Tmp1,Bcd2_7seg)
      shiftout Datapin,Clockpin,Tmp1,3    'send ones
      shift Tmp1,right,4
      shiftout Datapin,Clockpin,Tmp1,3    'send tens
const    Sa = 1        'segment a d0
const    Sb = 2        'segment b d1
const    Sc = 4
const    Sd = 8
const    Se = 16
const    Sf = 32
const    Sg = 64
const    Sdot = 128    'dot d7
Bcd2_7seg:
   data Sa+Sb+Sc+Sd+Se+Sf     'digit 0
   data Sb+Sc                 'digit 1
   data Sa+Sb+Sg+Se+Sd        'digit 2
   data Sa+Sb+Sc+Sd+Sg        'digit 3
                              'digit 4
                              'digit 5
                              'digit 6
                              'digit 7
                              'digit 8
                              'digit 9
Tripwire
PostPosted: Wed Jun 20, 2007 7:35 am    Post subject: Reply with quote
i don't get it :S i used your program to controll the display but i don't get anything on my displays not even 1 segment lights up.
i did this:
Dim Bteller As Byte
Dim Tmp1 As Byte
Dim A As Byte , C As Byte
      Bteller = 00
P1.5 = 1
P1.7 = 0
P1.6 = 0
      Print "persoon binnen " ; Bteller
      Waitms 50
      P1.5 = 0
      Waitms 10
      Bteller = 0
      Print "persoon weg " ; Bteller
      Waitms 50
      P1.5 = 0
      Waitms 10
If Bteller = 99 Then
   Bteller = 00
A = 63
C = 6
      Tmp1 = Makebcd(a)
      Tmp1 = Tmp1 And 15
      Tmp1 = Lookup(tmp1 , Bcd2_7seg)
      Shiftout P3.3 , P3.4 , Tmp1 , 3                         'send ones
      Tmp1 = Makebcd(c)
      Shift Tmp1 , Right , 4
      Shiftout P3.3 , P3.4 , Tmp1 , 3                         'send tens
Const Sa = 1                                                  'segment a d0
Const Sb = 2                                                  'segment b d1
Const Sc = 4
Const Sd = 8
Const Se = 16
Const Sf = 32
Const Sg = 64
Const Sdot = 128                                              'dot d7
Bcd2_7seg:
   Data Sa + Sb + Sc + Sd + Se + Sf                           'digit 0
   Data Sb + Sc                                               'digit 1
   Data Sa + Sb + Sg + Se + Sd                                'digit 2
   Data Sa + Sb + Sc + Sd + Sg                                'digit 3
   Data Sb + Sc + Sf + Sg                                     'digit 4
   Data Sa + Sc + Sd + Sf + Sg                                'digit 5
   Data Sa + Sc + Sd + Se + Sf + Sg                           'digit 6
   Data Sa + Sb + Sc                                          'digit 7
   Data Sa + Sb + Sc + Sd + Se + Sf + Sg                      'digit 8
   Data Sa + Sb + Sc + Sd + Sf + Sg                           'digit 9
Gianni
PostPosted: Wed Jun 20, 2007 12:11 pm    Post subject: Reply with quote
You forget to latch data into 4094; pulse pin 1
P3.2 = 1
nop
nop
P3.2 = 0
Pin 15 of 4094 must be High; connect to +5v
IMHO is not a good idea drive all the 7 leds with a single resistor; use separate resistors
Regards
Tripwire
PostPosted: Thu Jun 21, 2007 7:39 am    Post subject: Reply with quote
well the thing is when i program a microcontroller with a program i got from my teacher (last project) the displays work. so it has to do something with the program.
Tripwire
PostPosted: Wed Jun 27, 2007 10:24 am    Post subject: Reply with quote
hey got another question for you:
why do you do tmp1 = tmp1 and 15 ?
btw i'm getting a few segments that are lighting up so the program almost works
subar
PostPosted: Wed Jun 27, 2007 1:50 pm    Post subject: Reply with quote
this is the code you can get benifet from and i had excuted it works correctly... Razz
' port A 7 segment
' 0 -----------> a
' 1 -----------> b
' 2 -----------> c
' 3 -----------> d
' 4 -----------> e
' 5 -----------> f
' 6 -----------> g
$regfile = "m16def.dat"
Config Porta = Output
Porta = 255
Dim I As Byte
Dim X(16) As Byte
Restore Value_table
For I = 1 To 16
Read X(i)
For I = 1 To 16
Porta = Not X(i)
'Porta = X(i)
Waitms 500
Value_table:
Data &H40 , &H79 , &H24 , &H30 , &H19 , &H12 , &H02 , &H78
Data , &H00 , &H10 , &H08 , &H03 , &H46 , &H21 , &H06 , &H0E
many people know what to do,But few people do what they know.
Regards
subar
View user's profile Yahoo Messenger
Tripwire
PostPosted: Thu Jun 28, 2007 7:32 am    Post subject: Reply with quote
thx man but can you give me m16def.dat? i don't have the file Sad
sakaz
PostPosted: Thu Oct 15, 2009 12:18 am    Post subject: Reply with quote
Hi forum,
Hope you are doing well all. I have been working with Bascom AVR for last 2 years and i am so glad to learn alot of things from this great forum. I must thank all of you.
These days i am working on a project with the 7 Segment (Liquid Crystal Display) 6 1/2". and trying to drive with the Cd4094, CD4543 & CD4514 as per attached schematic.
I want to display my result on the 6 digit display but i am having some problem.
I want to lacht the CD4514 first to select the digit and then CD4543 to show the data but i cant.
'name : shift.bas
'purpose : example for SHIFTIN and SHIFTOUT statement
'micro : Mega48
'suited for demo : yes
'commercial addon needed : no
$regfile = "m8def.dat" ' specify the used micro
Dim L As Long
Config Pinb.0 = Output
Config Pinb.1 = Output
Config Pinb.2 = Output
Sipo_sck Alias Portb.0 'port for sck 74hc
Sipo_din Alias Portb.1 'data serial input
Sipo_latch Alias Portb.2 'latch pin
Sipo_sck = 0 'initial out
Sipo_din = 0
Sipo_latch = 0
Dim Data_sipo As Byte
Data_sipo = 0
Shiftout Sipo_din , Sipo_sck , Data_sipo , 1
Sipo_latch = 1
Waitms 100
Sipo_latch = 0
Wait 1
Shiftout Sipo_din , Sipo_sck , Data_sipo , 2 <---- LSB Shifted out first when Clock goes low.
Sipo_latch = 1
Waitms 100
Sipo_latch = 0
Waitms 100
Wait 1
Incr Data_sipo
But i inverse the data input lines as per:
11 ----- 2
12 ----- 3
13 ----- 21
14 ---- 22
Then it does work fine. Why i cant find the reason. please help.
Regards,
Post new topic   Reply to topic    www.mcselec.com Forum Index -> BASCOM-8051 All times are GMT + 1 Hour
