Posted: Mon Nov 12, 2007 4:59 pm Post subject: goto error
hello,
with this small program,"goto lampe" give error ;
if i replace with "goto begin " no error ......why?
because "Lampe Alias Portb.1" ??
we can't use the same name for label and variable ?
Marche AliasPortb.0' <<<<<<<< Marche is already used here as alias
Lampe AliasPortb.1' <<<<<<<< Lampe is already used here as alias
Transfo AliasPortb.2
Marchin AliasPinb.3
Begin:
Lampe:'<<<<<<<< rename the label Lampe in Lampe2 Waitms200
Transfo =0 Waitms200
Marche =0 Waitms200
Lampe =1 Waitms200
Transfo =1 Waitms200
Bitwait Marchin , Reset
Marche:'<<<<<<<< rename the label Marche in Marche2 Waitms200
Lampe =0 Waitms200
Marche =1 Waitms200
Bitwait Marchin , Set
Goto Lampe '<<<<<<<< rename the label Lampe in Lampe2
hi,
thanks Luciano,
i know your code will work,
my question was:
can't we use the same name for variable and label? _________________ G Daelen Namur Belgium
