Wall hugging bot
Post new topic   Reply to topic    www.mcselec.com Forum Index -> Robotics
BRY2005
PostPosted: Sun Jan 23, 2005 3:24 pm    Post subject: Wall hugging bot Reply with quote
Anyone have a simple outline for code for a wall hugging bot?Like to try a small one with two bumpers. Very Happy
DJD XTREEM
PostPosted: Mon Jan 24, 2005 12:13 pm    Post subject: Reply with quote
What do you mean by wall hugging??
Something that he search for a wall and then ride beside it..
Or search a wall and approach it from the front and stops...
I don't have a clue..
Bascom AVR 1.11.8.8 full version
STK500 Programmer
ISP Programmer
View user's profile Visit poster's website MSN Messenger
BRY2005
PostPosted: Wed Jan 26, 2005 1:53 pm    Post subject: Reply with quote
No,I mean the basis of a wall following robot,which would travel the perimeter of the room,and then perhaps later,branch out from there,but small steps first.Bry. Smile
DJD XTREEM
PostPosted: Thu Jan 27, 2005 10:30 pm    Post subject: Reply with quote
I think for wall following you need a little bit more than just 2 bumpers..
Because something has to detect how far your off a wall.. Because when a bumper is pressed your robot touch the wall and only when he leaves the wall the sensor resets himself..
So there is no vairable detection that 'looks' how far your off the wall..
Simple but effective.. IR led And ir reciever .. Same way lego has contructed there light sensor. This sensor can give a raw value to let you see how close an object is.. But there even better ways to do that..
Just search on the internet for such things as IR eyes, proximity detectors and on and on..
STK500 Programmer
ISP Programmer
eddy
PostPosted: Sat Jan 29, 2005 8:28 pm    Post subject: Reply with quote
It can be done with only one bumper. Tamiya sells a small wall hugging robot kit that is super simple.
http://www.pololu.com/products/tamiya/0075/
You can also find these at Frye's Electronics and numerous places on the web.
From there, you can modify it or build a different one that uses IR sensors to detect the wall without touching it.
Eddy
Eddy Wright
Wright Hobbies, LLC
http://www.wrighthobbies.net
DJD XTREEM
PostPosted: Sun Jan 30, 2005 11:58 am    Post subject: Reply with quote
This has nothing to do with micorcontrollers..
Because tamiya uses a very simpel system.. 1 wheel is always driven the other wheel will only run if the sensor is touched.. So when the first wheel runs, the sensors touches the wall and activate the second motor to correct the steering to the wall..
But yeah you can use a microcontroller to check the button and controll the motors Wink
STK500 Programmer
ISP Programmer
myblack60impala
PostPosted: Wed Feb 21, 2007 10:32 pm    Post subject: Reply with quote
Here's a link to some bascom sample code. Some of it was written by me, and the array code was found on the internet. Feel free to use it to make your robot.
http://www.robomo.com/Forum/viewtopic.php?t=606
Post new topic   Reply to topic    www.mcselec.com Forum Index -> Robotics All times are GMT + 1 Hour
