The following code snippet from Josef's "Flashcard-Demo.bas" shows how to do this, if I read it right:
'dim some test variables Dim S AsString*60 , Fl AsString*12 , Ff AsByte Dim Sdatetime AsString*18
Fl ="test.txt"
S ="test this"
'Now we are getting to it 'We can specify a file handle with #1 or #2 etc. or we can ask for a free ' file handle with the FreeFile function. It will return a free handle if there is one.
Ff =Freefile()' get a file handle
'With this file handle we refer to a file Open Fl ForOutputAs #ff ' open fikle for output ' we need to open a file before we can use the file commands ' we open it for OUTPUT, INPUT , APPEND or BINARY ' In this case we open it for OUTPUT because we want to write to the file. ' If the file existed, the file would be overwritten. Print #ff , S ' print some data Print #ff , S
Print #ff , S
Print #ff , "A constant"; S
Testsb Ff
Close #ff ' close file
'A file opened if OUTPUT mode is convenient to write string data too 'The next beta will support WRITE too
'We now created a file that contains 3 lines of text. 'We want to append some data to it
S ="this is appended" Open Fl ForAppendAs #150' we specify the file number now Print #150 , S
Close #150
The above is line number 80 through 113. As you can see, there is a line
F1 is a variable defined in line 83.
I would imagine that there is a way where you can read some data from your stroage device (SD card, or whatever) that would have information you could read into a variable. Just be sure that the variable is a string.
