Lookup table on a hex 100 boundary
dg4mec
PostPosted: Wed Jan 12, 2005 2:09 pm    Post subject: Lookup table on a hex 100 boundary Reply with quote
I look for a way to place a lookup table on a hex 100 boundary at end of flash ram. Is in Bascom-AVR a compiler function like in assembler " .org address "
DToolan
PostPosted: Wed Jan 12, 2005 8:35 pm    Post subject: Reply with quote
You can force the locations for variables in the following manner...
DIM MyArray1(36) As BYTE at $100 '<- RAM declaration
DIM MyArray2(36) As ERAM BYTE at $100 '<- EEPROM declaration
View user's profile Yahoo Messenger
dg4mec
PostPosted: Thu Jan 13, 2005 1:29 pm    Post subject: Lookup table on a hex 100 boundary Reply with quote
Many thanks to DToolan for his replay.
When I posted my question I gave to les info about my problem.
The table I use is 1024 Bytes long, so it will not fit in EERAM (512 Bytes) or it will consume all SRAM (1024 Bytes), based on a ATMega162 chip. For this reason I have to place it in "FLASH RAM".
Thanks for Your support.
DToolan
PostPosted: Thu Jan 13, 2005 9:17 pm    Post subject: Reply with quote
By "flash ram", I guess you mean the program storage area. You can use a DATA statement for your lookup table and that would place your table at the end of the used program storage. This would not necessarilly be at a hex 100 boundry though. A comma at the end of a line will continue the DATA statement through subsequent lines. Leave the comma off the last line of your DATA statement. The first element of a DATA statement is element zero.
Pretending a two dimensional lookup table that is 32 x 32 (1024 elements)... row 1, column 21 would be the 20th element. Also, since a byte can only go to 255, you may have to chop up your table into 32 rows. You'll have to experiment with the DATA statement and using bytes, words, etc. for pointers. The Bascom DATA statement can sometimes be finicky and while it may compile without error, you might not get the data element you expect. For instance, stick with one data type in your DATA statement (ASCII, Hex, Binary... whatever you choose). Mixing data types in the data statement... DATA "A", 65, &H41 may not always produce equal results even though all three of those items are equal.
It's possible you may be able to get by with one large table of 1024 and use a word for POSITION (I haven't done one larger than 255). There are many ways to accomplish any one task.
DIM ROW As BYTE
DIM POSITION As BYTE
DIM ANSWER As BYTE
'MAIN
DO
'do whatever math or offsets you need to figure out which element
'equates to the row and column your answer resides in.
ROW = something
POSITION = something else etc.
'subtract one because the DATA statement is zero based
DECR POSITION
SELECT CASE ROW
     CASE 1
              ANSWER = LOOKUP(POSITION, ROW_1)
     CASE 2
              ANSWER = LOOKUP(POSITION, ROW_2)
END SELECT
'if ROW equaled 1 (dec) and POSITION equaled 20 (dec) then ANSWER would be &H4C
LOOP
END
ROW_1:                                                 'lookup table
DATA &H08 , &HFE , &H54 , &HFE , &H59 , &H01 , &HFE , &H41 , &HFE , &H58 , &H20 , &H41 , &H4D , &H45 , &H52 , &H49 ,
DATA &H20 , &H41 , &H49 , &H52 , &H4C , &H49 , &H4E , &H45 , &H53 , &HA0 , &H02 , &H64 , &H03 , &H08 , &H07 , &H03
ROW_2:
DATA &H00 , &H00 , &H00 , &H00 , &H00 , &H00 , &H00 , &H00 , &H00 , &H00 , &H00 , &H00 , &H00 , &H00 , &H00 , &H00 ,
ROW_3:
dg4mec
PostPosted: Sun Jan 16, 2005 7:11 pm    Post subject: Lookup table on a hex 100 boundary Reply with quote
I used already the DATA statement to store my table in program area. The table was correctly stored, but in the middle of the machine code, and not on a hex &H100 boundary. Since the table is accessed by an fast assembler loop with only 6 instructions, I need the hex &H100 boundary. The table it self consists of 4 parts each 256 bytes long (sine, triangle, saw tooth and a square wave table).
I solved my problem using the compiler directive " $BOOT " which moved the DATA area to top of Program storage. The address I had to enter is the address divided by 2 (word address), but this is not documented in the help function.
Thanks to all which investigated on my problem.
