Track width 230V AC
Post new topic   Reply to topic    www.mcselec.com Forum Index -> PCB's
Sergei
PostPosted: Mon Feb 12, 2007 8:55 pm    Post subject: Track width 230V AC Reply with quote
This ths the first time that I work with pcb's and AC power but I wonder what the track width should be is a PCB track has to withstand 300W @230V AC
Well, there are several sections:
1x 300W
1x 90W
2x 80W
2x 50W
1x20W
There is a common supply so that track should be able to hold 540W @230V AC
If the track would be to wide, anything to fix that?
tkordaso
PostPosted: Fri Feb 16, 2007 5:56 pm    Post subject: Reply with quote
i don't have exact values, but from my memory: max allowed current for copper conductor is 3A/mm2 if insulated (in cable) or more in free air.
so you make calculation depending of copper thickness on your PCB.
if space is tight, you can add more solder to copper tracks, thus extending track thickness (and max current).
br
Tom
It must be user error
Sergei
PostPosted: Fri Feb 16, 2007 7:59 pm    Post subject: Reply with quote
OK, sounds logical and found confirmation also on the net.
Thanks tkordaso
tkordaso
PostPosted: Sat Feb 17, 2007 4:25 pm    Post subject: Reply with quote
u r welcome. Just make sure to have good clearance between 230V tracks and rest of your circuit.
Sergei
PostPosted: Sun Feb 18, 2007 10:07 pm    Post subject: Reply with quote
Plenty of room, ac part is placed on it's own board and even the connections to the processor are protected with optical solution.
ryoung
PostPosted: Tue Dec 18, 2007 12:57 pm    Post subject: track spacing Reply with quote
There are standards applicable to pcb spacing for any voltage applied. These are not arbitary values , the standards are there for reasons, NEVER forget this. It also depend on coating on pcb, humidity, type of pcb (all are not the same). Call up your local PCB manufacturer, mthey will probably willingly supply the local requirements. There are 2 x main standard groups, USA and the rest of the world ie EU standards. Dont get me wrong, this is not a USA vs others thing it is really separate groups that have set up differnt testing and monitoring systems that differ. If I remember correctly, the enclosure manufacturere "Rittal" have an electronics enclosure section that has spacing values for voltages vs environmental conditions etc. Have a look on the web.
I hope this helps a little.
Frankeman
PostPosted: Tue Dec 18, 2007 8:49 pm    Post subject: Reply with quote
Google is your friend.
http://www.desmith.com/NMdS/Electronics/TraceWidth.html
http://www.pcbco.com.au/tracecalc.html
http://www.4pcb.com/index.php?load=content&page_id=95
And much more, search for "trace width calculator"
Frank.
Post new topic   Reply to topic    www.mcselec.com Forum Index -> PCB's All times are GMT + 1 Hour
