Erratic Lines on Graphic LCD T6963C
MadMax
PostPosted: Fri Jan 26, 2007 10:43 pm    Post subject: Erratic Lines on Graphic LCD T6963C Reply with quote
Hi All,
I'm using:
Mega128 @ 8MHz ceramic osc
Graphic LCD (T6963C) on Port A and Port C.
(Lumex 240 x 128) LCMS240128GSF
I'm writing to the display fine, but occasionally I do get some stray lines when writing to the display. I don't have any interrupts or timers running.
I found this thread: http://www.mcselec.com/index2.php?option=com_forum&Itemid=59&page=viewtopic&t=2478&highlight=t6963c
Can anyone comment on whether this is worth trying or if they've had similar experiences.
Thanks in advance.
Max
View user's profile Visit poster's website MSN Messenger
jboavida
PostPosted: Sat Jan 27, 2007 2:25 pm    Post subject: Reply with quote
I had a similar problem but with a KS108 display.
Maybe it can help you
Check this:
http://www.mcselec.com/index2.php?option=com_forum&Itemid=59&page=viewtopic&t=2188&highlight=
If you can find similar code in the T6963C library maybe it can help.
Joaquim
beamer
PostPosted: Sat Jan 27, 2007 6:38 pm    Post subject: Re: Erratic Lines on Graphic LCD T6963C Reply with quote
MadMax wrote:
Hi All,
I'm using:
I found this thread: http://www.mcselec.com/index2.php?option=com_forum&Itemid=59&page=viewtopic&t=3476
Thanks in advance.
Max
Max: I had a similar problem, if your lucky it could be the same issue.
If the issue is timing you can simply tell the compiler that you are using a 12Mhz crystal for instance, in this way you will fool the compiler into increasing delays. Try this first before changing library files because if it does not fix the issue, you may have a different kind of problem.
Regards
Chris
juanen
PostPosted: Sun Jan 28, 2007 12:23 pm    Post subject: Reply with quote
fuse jtag activated: NO
fuse m103 compatibility: NO
use m128def.dat
other solution in crystal fuse, internal crystal no problems but use external crystal, use last fuse external crystal, not other.
Kasch
PostPosted: Sat Jul 07, 2007 5:10 pm    Post subject: Reply with quote
i have the same problem with a T6963C-Display on 240x128
latest bascom-full-version
m64
dataport A
Controlport C
8Mhz extern crystal
all wiring are correct, software 100times examined
text displayed very good, but with grafic is only mismatch...i have no 3k3 resistors at home, but i can't resists, that only hand added resistors are the only solution...who fixed the problem without this?
thank you
chr-mt
PostPosted: Sat Jul 07, 2007 5:30 pm    Post subject: Reply with quote
seems that the timing for Grapic LCDs is critical.
I had success with pullup resistors with the one Display,
but tried on different Display and it didn't work.
I found, that signal quality on the datalines was not very good and had DC- offset.
Make shure you use short cables.
Just for testing, you can try to tell bascom that you use a higher crystal frequency than you actually do, like beamer said.
For Example, if you use 8MHz, set: $crystal=16000000
This will force Bascom to make the timing slower.
All your Wait commands will also be slower, and also Uart,
so this is only a trick, to find out if your Display-Hardware and your Program are OK.
regards
Christopher
Kasch
PostPosted: Sat Jul 07, 2007 5:54 pm    Post subject: Reply with quote
i try this, but nothing is better. it stills graphic trash..
chr-mt
PostPosted: Sun Jul 15, 2007 12:32 pm    Post subject: Reply with quote
maybe you should try to increase stacksize ?
Christopher
