GeertJ
SvendP
Posted: Thu Dec 07, 2006 11:55 am Post subject: |
Hi.
That is perfectably normal for en LCD display to behave like that.
The adress for charaters are line 1 - 3 - 2 - 4.
So you will have to live with it.
Regards
Svend |
SvendP
Posted: Thu Dec 07, 2006 12:04 pm Post subject: |
Hi.
Regards
Svend |
GeertJ
Posted: Fri Dec 08, 2006 2:21 pm Post subject: |
forgot to mention this, when I write something on the fourth of third line, so with this code
Code: |
Locate 3,1
Lcd "write something"
locate 4,1
lcd "write something"
he write's it on the second and fourth line, but he starts in the middle of the line (think on character 10 or so)... |
Gianni
Posted: Sun Dec 10, 2006 12:45 pm Post subject: |
Hi.
You can try to slow down the cpu clock frequency to 2-5MHz
Sometimes a delay may help
Locate 3,1
delay
locate 4,1
delay
Regards |
GeertJ
Posted: Sun Dec 10, 2006 3:09 pm Post subject: |
Tried that, but no changes in lcd  |
Gianni
Posted: Mon Dec 11, 2006 10:20 am Post subject: |
I suppose that the display is not 100% HD44780 compatible.
I can only suggest to write your own routine for locate,cls,lcd,cursor,.
Then redirect the output to your lcd routine with $serialoutput and replace the lcd statement with print.
Regards |
GeertJ
Posted: Mon Dec 11, 2006 10:59 am Post subject: |
yep, thats probably the problem, the LCD that I use has the KS0073 controller on board, which is, i qoute the manufacture, "almost 100% compatible with the HD44780 controller"....  |
