Dim New As Bit
Dim Command As Byte , Subaddress As Byte
Reset Tcon.0 'triggered by rising edge
On Int0 Receiverc5
Enable Int0
If New = 1 Then 'received new code
Disable Int0
' Print Command ; " " ; Subaddress
Print Command '; " " ; Subaddress
New = 0 'reset new bit
If Subaddress.5 = 1then
Print "toggle bit set"
Subaddress = Subaddress And &B00011111
Enable Int0
Receiverc5: 'interrupt routine
'the getrc5 routine uses 30 bytes ! of the stack for measuring
'the interval between the bits
Getrc5(subaddress , Command)
New = 1 'set flag
