antonio1964
Posted: Sun Oct 15, 2006 12:12 pm Post subject: Problem receiving data from serial port with modem TC35i |
Hello, i am new to this field. I have started to program AT89C51 microcontrollers.
I had done transmitting data via serial port successfully and received data
on hyper terminal on pc, but when i'm going to receive it from modem tc35i, only receive one character. (response "OK" but only receive "O").
Sure my program is bad. Please help me . Thank you. This is my code:
' Send & Receive to MODEM
' Equipos:
' Modem GSM Siemens TC35i
' Antonio
' 10-Oct-2006
Declare Sub Sacadatos(s As String * 20)
Dim T As Integer
Dim S As String * 20 ,
Dim A As Byte
$baud = 4800
Config Lcd = 20 * 2
Enable Serial
'p3.7 is a switch
P3.7 = 0
'Init
Cls : Locate 1 , 1 : Lcd "Init................"
Print "ATZ" : Wait 2
Cls
'Send AT Command
Print "AT" 'AT
'Receive data and prompt
Sacadatos S : Locate 2 , 1 : Lcd S : Wait 1
'Send ATI Command
Print "ATI" 'ATI
Loop Until P3.7 = 1
'END
CLS: Locate 1 , 1 : Lcd "END PROGRAM "
Disable Serial
'Read Data from MODEM
S = "" : T = 0
T = Inkey
If T > 0 And T <> 10 And T <> 13 Then
S = S + Chr(t)
Loop Until T = 10
End Sub
Funci
Posted: Tue Oct 17, 2006 12:34 pm Post subject: |
Are you sure that you have correct baud rate? |
antonio1964
Posted: Tue Oct 17, 2006 3:26 pm Post subject: |
The modem is set as autobaudrate. I can send without problems.
How does the "SCON" register work? Can you explain it to me?
Thank you. |
Funci
Posted: Wed Oct 18, 2006 2:33 pm Post subject: |
I don't know how to explain Scon, because I don't using it. But my advice about your problem is to change conception of your program!
Try to make program without calling subrutines, I am thinking that you spend to much time on that jumps, or try the same program but with very slow baud! |
kimmi
Posted: Mon Nov 20, 2006 12:06 am Post subject: |
hi antonio1964,
dont know the right commands for 80xx avr
but can you make a buffer for input like a ringbuffer size(max uotput len from modem)
then
send command
wait some time (150 -250 ms)
read from modem (stored in buffer) _________________ / Kim |
