eurotimedate Query
abifar1
PostPosted: Wed Aug 02, 2006 8:31 pm    Post subject: eurotimedate Query Reply with quote
Hi
I need a tip about how using "eurotimedate.lib" because I use RTC ds1307 and this code for date format same as "02/27/06" :
$lib "ds1307.lib"
$lib "eurotimedate.lib"
Config Clock = User
Config Date = Mdy , Separator = /
but problem is when I change Conifg to :
Config Date = dmy , Separator = .
it does not effect and date format is same as before "02/27/06" !! Shocked
what I am doing wrong ? can anybody tell me ?
View user's profile Yahoo Messenger
DToolan
PostPosted: Wed Aug 02, 2006 10:02 pm    Post subject: Reply with quote
You are mixing too many statements that are competing for control and the ds1307.lib is winning. If you want to use the ds1307.lib, it is preset for MM/DD/YY display.
If you want to use the eurotimedate.lib, it is preset for DD-MM-YY (no periods as seperators).
Your "CONFIG DATE =" statements seem to have no effect if you use any $lib designed to do Date$ control.
ATIU
PostPosted: Wed Aug 02, 2006 10:52 pm    Post subject: Reply with quote
You can probably combine both libraries, cut and paste, and modify the separator as well. Open the library and it should be pretty staight forward since its very well commented/documented.
kimmi
Moderator
PostPosted: Thu Aug 03, 2006 1:01 am    Post subject: Reply with quote
hi ...
try this Rolling Eyes
$regfile = "m8def.dat"
$crystal = 4000000
$baud = 19200
$hwstack = 32
$swstack = 10
$framesize = 40
Dim A As Byte
'[now init the clock]
Config Date = Dmy , Separator = .       ' Dmy not dmy
Config Clock = Soft                     'this is how simple it is
'The format is DD/MM/YY
'Date$ = "03.08.06"
' Time$ = "02:20:00"
'test on date  Day step up every sec
A = 1
_day = A'  a seep date by 1 to see it is ok
_month = 08
_year = 06
  Print Date$ ; "  " ; Time$            'show the date and time
Wait 1
A = A + 1
If A > 31 Then A = 1
Rolling Eyes
/ Kim
View user's profile Visit poster's website MSN Messenger
kimmi
Moderator
PostPosted: Thu Aug 03, 2006 1:42 am    Post subject: Reply with quote
this work ok to
$regfile = "m32def.dat"
$crystal = 8000000
$baud = 19200
$hwstack = 32
$swstack = 10
$framesize = 40
$lib "ds1307rtc.lib"
'$lib "eurotimedate.lib"
Dim A As Byte
Config Date = Dmy , Separator = .       ' ANSI-Format
Date$ = "03.08.06"
'Time$ = "02:20:00"
A = 1
_day = A
Wait 1
A = A + 1
Shocked
01.08.06 02:20:00
02.08.06 02:20:30
$crystal = 8000000
$baud = 19200
$hwstack = 32
$swstack = 10
$framesize = 40
Dim A As Byte
Config Date = Mdy , Separator = .       ' ANSI-Format
'The format is MM/DD/YY
Date$ = "03.08.06"
'Time$ = "02:20:00"
A = 1
_day = A
Wait 1
A = A + 1
03.01.06 02:21:11
03.02.06 02:21:12
/ Kim
abifar1
PostPosted: Thu Aug 03, 2006 12:02 pm    Post subject: Reply with quote
DToolan and ATIU Thank you very much I think your right I should change in DS1307.lib but it is a pittule difficult for me because I dont know too much Assbmly . I am trying if it works I tell you .
but I think easiest way for me is just change string or DATE by a Sub in Bascom .
KIMMI I dont get what are codes you are writnig seems you did not get the query !! Exclamation
kimmi
Moderator
PostPosted: Thu Aug 03, 2006 2:51 pm    Post subject: Reply with quote
ohhh sorry
Do you have Phil´s ds1307rtc.lib ?
'get date & time from the DS1307 & convert it to binary & stick it in the
'global variables _sec, _min, _hour, _day, _month. _year
'This routine is called automaticly whenever the "Date$" or "Time$" is read. (I guess, because it is not documented)
'This routine must be called maunally, just prior to, whenever a other time & date routines are used,
'eg "SysSecElapsed" & "SysSec()"
/ Kim
