Interrupt with NOSAVE option
This forum is locked: you cannot post, reply to, or edit topics.   This topic is locked: you cannot edit posts or make replies.    www.mcselec.com Forum Index -> BASCOM-8051 Archive
FanieTerblanche
PostPosted: Tue Aug 01, 2006 3:48 pm    Post subject: Interrupt with NOSAVE option Reply with quote
Hi All,
I would like to know how to determine what registers to save when i am using the NOSAVE option for INT0.
Thanks in advance.
Vilko
PostPosted: Tue Sep 19, 2006 9:01 am    Post subject: I usualy do this way Reply with quote
It depends on your interrupt subroutine, what register are to be saved: those, used in the subroutine.
If the subroutine is in Basic, i usually do this way:
I compile subroutine extra, disasseble it and look at assemble list, which tells me, what reagisters are used.
I usually use NOSAVE option only with very simple ISR like
INCR variable or Set bitvariable
return
and variable must be one byte.
Yes, it is thrue, on 128 Bytes of RAM, Save takes about 20 bytes fo Stack.
This forum is locked: you cannot post, reply to, or edit topics.   This topic is locked: you cannot edit posts or make replies.    www.mcselec.com Forum Index -> BASCOM-8051 Archive All times are GMT + 1 Hour
