alext
Posted: Fri Jun 16, 2006 8:58 pm Post subject: Can't use Inverted in Open command |
Hi everybody
I have a problem using the option INVERTED with the open command to communicate two at89c2051
Im using:
Open "com3.7:4800,inverted" For Output As #2 in one of the micros
and
Open "com3.7:4800,inverted" For input As #2 in the other
I'm sending the following data
dig() is a byte variable
Dig(1) = 1
Dig(2) = 2
Dig(3) = 3
For I = 1 To 7
Put #2 , Dig(i)
Waitms 5
Next I
I receive other values in the second micro. What is the problem ??
Thanks for any help |
Frankeman
Joined: 11 Aug 2004 Posts: 948 Location: the Netherlands
Posted: Fri Jun 16, 2006 9:32 pm Post subject: |
If the 2 micro's are directly connected simply don't use the inverted command.
Is the ground of the 2 micro's connected ?
Frank. |
alext
Posted: Sat Jun 17, 2006 12:34 am Post subject: |
Hi Frank
At first, I didnt use the inverted option, and the transmission was Ok, but when I wasnt transmiting info, the channel stayed in logical 1 (high voltage). I'm using a RF transceiver with AM or OOK modulation to communicate the 2 micros, and I want to invert the output signal so when Im not sending data the RF transceiver dont generate the signal
What can I do??? |
Frankeman
Posted: Sat Jun 17, 2006 7:33 am Post subject: |
If non inverted works and inverted not than the chance is great that it is a software bug.
What happens if you wire the to micro's together and than communicate,
is the inverting mode than also not working?
In the worst case the inverting can be done in hardware. |
4Stroke
Posted: Sat Jun 17, 2006 12:03 pm Post subject: |
Isnt it
Open "com3:4800,inverted" For Output As #2
or
Open "comD.7:4800,inverted" For Output As #2
Instead of
Regards Nathan |
Frankeman
Posted: Sat Jun 17, 2006 4:58 pm Post subject: |
The ports on 8051 chips have a number in contrast with an avr who uses a letter.
So open "com3.7:4800" means port 3, pin 7
Frank. |
alext
Posted: Mon Jun 19, 2006 8:54 pm Post subject: |
Hi Frankeman
I think it would be better to do it in hardware. Now I have another question...
I can send a byte array without problem with the commands
Put #1 , Dig(i) and
Get #1 , Dig(i) Timeout = 100
but now I'm trying to send a string variable with
Dim Id As String * 5
id = "AR234"
Printbin #1, id and
inputbin #1, id
but the other micro receives just one character at a time an I need to define more varaibles to receive the next characters
Is there any way to receive the whole string with just one variable??? |
Frankeman
Posted: Mon Jun 19, 2006 10:36 pm Post subject: |
you can't send a string like that, the string must be send char by char
Code: |
dim id as string * 5
dim L as byte
dim N as byte
dim A as byte
id = "AR234" 'assign string
L = len(id) 'get length of string
for N = 1 To L 'for all characters from left to right
A = mid(id , N , 1) 'get character
put #1 , A 'write it to comport
next
alext
Posted: Wed Jun 21, 2006 9:06 pm Post subject: |
Hello everybady
At last I could resolve the problem of the INVERTED option.
The initial state of the port P0.7 remained on high voltage (1L) so I changed it to low with RESET P0.7 and finally it worked out!!!!!
And I could send the whole string too, without problem and just with one instruction.
Thanks everybody for your help
Regards
ALEX |
