mr_tembo
Posted: Wed Jun 14, 2006 1:18 pm Post subject: Newbie need help - EDB-Board and LCD |
we had buy the "edb" board to learn some.
The Sample file we had flash, but the LCD show nothing.
We think we must change some settings in "Options/Compiler/LCD" , but we dont know what:
The source code show like this:
$regfile = "m32def.dat"
$crystal = 38400
Locate 1 , 1 : Lcd "Hello World "
We do not use a m32 processor we have a m88. so please help us.
Greetings Michael |
Frankeman
Joined: 11 Aug 2004 Posts: 948 Location: the Netherlands
Posted: Wed Jun 14, 2006 3:50 pm Post subject: |
Hi and welcome to this friendly forum.
In your little test code there are four mistakes:
1 the regfile is wrong
2 the crystal frequency is wrong
3 the do..loop is not needed
4 the type and connection of the lcd is not given
Code: |
$regfile = "m88def.dat"
$crystal = 3840000
Config Lcd = 16 * 2
Locate 1 , 1
Lcd "Hello World "
You have to change the Config lines for the display type and connection.
Frank. |
mr_tembo
Posted: Wed Jun 14, 2006 5:04 pm Post subject: |
Hi Frank,
thanks for your Reply. We had make exact your Sample. Now we got from the Compiler the following Message:
In Line 8 ("End")
Error 40 Variable can not be used with RESET (PORTA) ,in File...LCDTEST:BAS
Error 41 Variable can not be used with SET (PORTA) ,in File...LCDTEST:BAS
$crystal = 3840000
Config Lcd = 16 * 2
Locate 1 , 1
Lcd "Hello World."
End 'end program
Whats he want from us.
Michael |
mr_tembo
Posted: Wed Jun 14, 2006 6:22 pm Post subject: news to the problem |
i had change the $regfile to "m23def.dat", after this in the simulator its work and no errors, but not at the boartd (ok normal) if we change back to
we got all the errors again...
Please help us... |
Frankeman
Posted: Wed Jun 14, 2006 9:46 pm Post subject: |
This is because the m88 has no port A.
Change the "Config lcdpin" so that the portpin assignments are correct for your case.
ps
With the $crystal you set the frequency which the m88 is running.
34800 is a common baudrate and not a frequency. |
mr_tembo
Posted: Thu Jun 15, 2006 8:58 am Post subject: |
Strike, with this setting it work fine:
Config Lcdpin = Pin , Db4 = Portb.2 , Db5 = Portb.3 , Db6 = Portb.4 , Db7 = Portb.5 , E = Portb.1 , Rs = Portb.0
Thanks for your info.
greetings michael |
Posted: Tue Jun 20, 2006 11:53 pm Post subject: |
On the EDB CD you will find many samples.
And the LCD samples contain the proper CONFIG LCD lines. _________________ Mark |
