Frankeman
Joined: 11 Aug 2004 Posts: 948 Location: the Netherlands
Posted: Tue Jun 06, 2006 6:03 pm Post subject: Speedtest |
Has somebody perform a speedtest between an IIM7000A (memory mapped) and an IIM7010A (I2C).
I do not need real speed, but if the 7010 is slow i go for the 7000
Frank. |
bfdegraaff
Posted: Tue Jun 06, 2006 6:31 pm Post subject: |
Hello Frankeman,
Speed is a very relative word, I don't think the IIM7010A (I2C)
is slow. I have tested both the IIM7010A (I2C) and the IIM7000A.
It depends on what you want to do, personally I would use the
IIM7010A (I2C) for client based applications or small scale
server and the IIM7000A for server applications.
(note that this is an opinion)
If you visit a webpage using the IIM7010A (I2C) and you hit
F5 a couple of times then Firefox can show a Time Out page every
now and then. (specially with multi user)
If you really want power then the IIM7000A with ATMega128 is
nice. (The more flash the more HTML pages)
I see your location is Holland near The Hague if you want you can
test around with my TWI board.
Regards,
Barry de Graaff _________________ ______
Barry de Graaff is a micro electronics student,
formerly on work emplacement at MCS Electronics.
www.barrydegraaff.tk/edb |
Frankeman
Posted: Tue Jun 06, 2006 8:37 pm Post subject: |
Hi Barry,
I have both the 7000 and the 7010 module with the tcp-ip board here on my desk.
The tcp-ip board works with the 7000 perfectly, but to be honest i'am till this day to lazy to connect the 7010 and do a speedtest.
I tought maybe somebody else did the testing
You did some test but measered no byte/sec i believe, maybe you can express it in a factor like 4/1 that would be enough for me.
Frank. |
bfdegraaff
Posted: Thu Jun 08, 2006 12:18 pm Post subject: |
Hello Frankeman,
This is not as simple as it looks,
There are two options,
1. You send me some source code and I'll submit the load times here.
or
2. I can write a program this weekend that sends data
PNG files or something and see how the byte per sec are send.
The only problem is that I don't have and IIM7000 so I can't
compare the two.
Just tell me which one you prefer.
Regards, Barry _________________ ______
Frankeman
Posted: Thu Jun 08, 2006 8:44 pm Post subject: |
If you would be so kind to write the software i will set up the hardware simultaneously so testing is very easy.
Maybe it is an opportunity to send the result to MCS so they can publish it.
Frank. |
bfdegraaff
Posted: Fri Jun 09, 2006 2:15 pm Post subject: |
Hello Frankeman,
Here are the test results:
Parameters:
ATMega162 internal oscillator at 8 MHz with IIM7000a,
Using Firefox 1.5.0.4 with Fasterfox plugin 1.0.3
Sending 4170 in 2,484 sec (average of 3 loads)*
4170 in 2,484 sec equals 1679 bytes/ sec
ATMega32 internal oscillator at 8 MHz with IIM7010a,
Sending 4170 in 24,540 sec (average of 3 loads)*
4170 in 24,540 sec equals 170 bytes/ sec
* Note that in fact the speeds are a little bit higher
since I have not added the header bytes
(Content-Length: " + Str(filesize) + "{013}{010} etc...)
to the number of bytes send. But the times shown
is the time to send the data including headers.
Tests were performed using a peer-to-peer cable <1 M.
THIS TEST HAS NOT BEEN APPROVED IN ANY WAY
IT IS THUS TO BE CONSIDERED AS A VERY ROUGH ESTIMATION!
Best Regards,
Frankeman
Posted: Fri Jun 09, 2006 5:49 pm Post subject: |
Hi Barry,
Thanks for the test.
It looks like the 7000 is 10 times faster than the 7010.
Maybe it is not a supertest but it will do for me.
170 bytes per sec is not very much, but the pcb will be must easyer to develop.
Frank. |
