Posted: Thu May 11, 2006 10:49 pm Post subject: Problem building the sample program for easyTCPIP
Hi every one,
I have a problem building the sample code form the easy tcpip manual. I get the error message 86 (Invalid parameter for timer configuration [TWI] and Invalid parameter for timer configuration [CLOCK]). The config statement I use is the following:
Config Tcpip = Int0 , Mac = 00.40.12.34.56.78 , Ip = 192.168.0.8 , _
Submask = 255.255.255.0 , Gateway = 192.168.0.1 , Localport = 1000 , _
Tx = $55 , Rx = $55 , Twi = &H80 , Clock = 400000
the version of my Bascom Compiler is : 1.11.7.7. Can any one please help me out? When I comment the "Twi = &H80 , Clock = 400000" part the rest is compiled properly. But again I use a I2C connection on an easy TCPIP board with 7010A adapter board.
Another question: Is it ok if I supply the adapter board with 5V instead of 3.3V? Usually all the 3.3V devices are tolerant to 5V supply. Thnak you for the help.
