NM7010a shadow registers difficulties
This forum is locked: you cannot post, reply to, or edit topics.   This topic is locked: you cannot edit posts or make replies.    www.mcselec.com Forum Index -> Easy TCP/IP Archive
gz
PostPosted: Tue May 09, 2006 12:31 am    Post subject: NM7010a shadow registers difficulties Reply with quote
Hello!
I am using NM7010a module in indirect mode. I tested my circuit with iftest program provided by Wiznet. All the tests were passed (writing/reading to all common registers, I could even ping the module), but sometimes test of pointer registers which are accessed via shadow registers failed. I focused to the shadow registers only and ran the test in the loop. There were 30 to 50 % of errors and the errors apeared randomly. I prolonged the delay after writing to the shadow register, but there was no improvement. I am also quite sure that errors apear when reading (I made the test with just one write and many readings - 30 to 50 % errors).
I am wondering, if someone had similar problem. I appreciate any help.
I didn't find any useful information on the Wiznet homepage, nevertheless some topics were opened regarding this problem. I have got a feedback from a NM7010a user who told me that this could be also a firmware problem in NM7010a module and suggested me to move to NM7010Bb, which doesn't have shadow registers.
Gregor
This forum is locked: you cannot post, reply to, or edit topics.   This topic is locked: you cannot edit posts or make replies.    www.mcselec.com Forum Index -> Easy TCP/IP Archive All times are GMT + 1 Hour
