RS232 ? Mega8
kimmi
Moderator
PostPosted: Tue Apr 25, 2006 1:13 pm    Post subject: RS232 ? Mega8 Reply with quote
Hi All ..
How can I use the rx on the Mega8
Trying to read data send from GSM Phone 19200 baud
cant find the data i recive
I use this as read rx
__________________
Sub Rs232_data
Buf_Rs232 = ""
While _rs_head_ptr0 <> _rs_tail_ptr0
In_Rs232 = Inkey()
If Asc(In_rs232) > 32 Then
Buf_Rs232 = In_Rs232 + In_rs232
Print Buf_Rs232
Wend
End Sub
Is this not for Mega8 ?
anyone got some rs232 tx rx source for M8
:roll:
/ Kim
View user's profile Visit poster's website MSN Messenger
i.dobson
PostPosted: Tue Apr 25, 2006 3:10 pm    Post subject: Reply with quote
This should work on most AVR's. It just echos back the input.
'---[ Define stack space required ]--------------------------------------------
$hwstack = 40 'from the stack analysis
$swstack = 12
$framesize = 24
declare sub Test(byval txt as Byte)
$crystal = 11059200
$regfile = "m32def.dat"
$baud = 9600
Config Serialin = Buffered , Size = 10
Dim Serialchar As Byte
While Ischarwaiting() <> 0
  Serialchar = Inkey()
   print ;chr(serialchar);
wend
Hope this helps
Regards
Ian Dobson
kimmi
Moderator
PostPosted: Tue Apr 25, 2006 4:39 pm    Post subject: Reply with quote
Hi ..
Tnx for replay ..
still canīt get it to read the rx in to a string
if I do this :
Print "AT" ' send AT to phone get OK back
need to read this data from phone :
Print "AT+CSCA"
the phone send this :
+CSCA: "+4540390999",145
but M8 cant read it
have tryed all sources from forum now no luck
the rx in mega8 wont work but TX is ok
/ Kim
Eugen
PostPosted: Wed Apr 26, 2006 8:40 am    Post subject: Reply with quote
Hello,
Just some thoughts:
1) Your source is not correct, but perhaps its only a typo:
Sub Rs232_data
Buf_Rs232 = ""
In_Rs232 = Inkey()
------------------------------------------>above line is wrong, must be:
Buf_Rs232 = Buf_Rs232 + In_rs232
Print Buf_Rs232 ---> Perhaps you want the print of the received data after the wend?
Wend
End Sub
2) Are you calling your routine RS232_data frequently? Unlike the print statement, the receiving does need more attention! The Inkey-situation must be polled all the time, as the serial transfer is much slower than the program speed. That means that you will not see data everytime you call the routine. And you can't expect that when exiting the while-wend you have a complete transferred record.
3) You need to decide when the transmit is ready. Typically AT messages from modems (and cellphones) are terminated by CR-LF. or only CR - check the specs. You can take care for both terminations by finalising the buffer after CR has occured and ignoring all LFs.
Hope to help a bit,
Eugen
kimmi
Moderator
PostPosted: Wed Apr 26, 2006 9:44 am    Post subject: Reply with quote
hi Eugen ..
it was a type O
but cant use (CR) because it send (13) (10) in start and finish like this
in Hex :
0D 0A 4F 4B 0D 0A > 13 10 OK 13 10
0D 0A 2B 43 53 43 41 3A 20 22 2B 34 35 34 30 33 39 30 39 39 39 22 2C 31 34 35 0D 0A > 13 10 +CSCA: "+4540390999",145 13 10
Shocked
/ Kim
Eugen
PostPosted: Wed Apr 26, 2006 11:37 am    Post subject: Reply with quote
You can still use CR LF as termination recognition, do something like this:
if Cr then
        check if buffer is empty
        If buffer empty then
             ignore cr, carry on listening to rs232
        elseif buffer= OK then
             set OK flag or whatever
        else
             take buffer into received-string and work with received-string
        end if
elseif not LF
       buffer=buffer + received character
end if
Furthermore you can reduce the OK flood with
ATE0 - switches echo off
ATV0 - replaces <13><10>OK<13><10> with 0<13>
if you get 0 then OK, other numbers are errors
Regards,
Eugen
kimmi
Moderator
PostPosted: Wed Apr 26, 2006 8:27 pm    Post subject: Reply with quote
Hey Eugen .. Very Happy
have found the problem .
it was stored in the eram not in eeprom thats was my
problem to find it now it works fine
tnx for your help
Razz
/ Kim
