jayantskathe
Posted: Mon Mar 27, 2006 6:43 pm Post subject: LCD interface |
I have downloaded the demo version and connected P0 to LCD data bus
P2.0 to RS , P2.1 to Rw and P2.2 to E of the 89S52.
THE LCD is 16 *2 JHD 162A
No display is coming
Please help ?
jk |
Sergei
Posted: Mon Mar 27, 2006 8:16 pm Post subject: |
Most common error is wrong contrast voltage.
Some LCD's work with positive contrast line, others with negative.
Some with negative have onboard voltage converter, others not.
that depends on the manufacturer of the LCD.
So follow the datasheet specifications of the LCD. |
jayantskathe
Posted: Tue Mar 28, 2006 7:10 pm Post subject: LCD problem |
That was solved lonng back.
a) I was able to set contrast
b) I was able to write from asm files outside bascom.
c) That too only on the first line. all efforts to write to second line failed
d) bascom is not working for me.
.....pl..... help ....
jayant |
yugaja
Posted: Wed Mar 29, 2006 4:08 pm Post subject: |
You dont need a wire from uC to RW pin of LCD module! Just connect RW to GND. |
jayantskathe
Posted: Fri Mar 31, 2006 1:25 am Post subject: Pl send code with "hello" on LCD |
Hello all
I have been trying for two weeks with
P0 to LCD data bus
I cannnot still write to the LCD.
Please .....Please ... some body send code that
writes "hello" in line one and line two.
regards
jayant
www7574
Posted: Thu May 18, 2006 3:44 pm Post subject: |
well |
max
Posted: Fri May 19, 2006 9:49 am Post subject: |
What is your code... post it and we will look at it.
Have you set the configs etc |
