Posted: Sun Mar 26, 2006 3:10 am Post subject: Sample Electronics ISP and Reset Disable
If I set the fuse to use an AVR Reset pin as an I/O, can the chip still be programmed with the Sample Electronics ISP?
I assume it needs 12V to reset the chip, can the parallel port provide the necessary voltage? If not is there another DIY ISP solution that can?
