More than 2 INT pins..
zolsi
PostPosted: Sat Mar 25, 2006 4:46 pm    Post subject: More than 2 INT pins.. Reply with quote
Wich atmel avr µc is handle by bascom and has more than 2 interutp pins ? (atmega103 ?)
Thank you !
Cool
bzijlstra
Bascom Ambassador
PostPosted: Sat Mar 25, 2006 5:31 pm    Post subject: more than one interrupt.... Reply with quote
Atmega32 has two pins for interrupts. And how do I know that? I go to www.avrfreaks.net and click devices. Get a list with all AVR's with all features and a layout of the chip.
Lot's of info on that site.
Have fun
Ben Zijlstra
zolsi
PostPosted: Sat Mar 25, 2006 7:28 pm    Post subject: Reply with quote
haha
very friendly answer thank you !!
btw, i asked for MORE than 2 INT pins ...
i.dobson
PostPosted: Sat Mar 25, 2006 7:42 pm    Post subject: Reply with quote
Have a look at a mega48 or mega88. They have a 2 external interrupts and several pin change interrupts on port C.
Regards
Ian Dobson
Luciano
PostPosted: Sat Mar 25, 2006 8:11 pm    Post subject: Reply with quote
About the pin change interrupts.
(ATmega48, ATmega88, ATmega168).
There are 3 Interrupt Vectors (Interrupt routines) for the
PCINT0 for the pins PCINT7..0.
PCINT1 for the pins PCINT14..8
PCINT2 for the pins PCINT23..16
Best regards,
Luciano
Interrupt Vectors in ATmega168:
zolsi
PostPosted: Sat Mar 25, 2006 8:45 pm    Post subject: Reply with quote
Thank you for this infos.
in fact i need 3 int pins for : the easy tcp/ip + 2 flowmeters. Wich µc would you choose ? Pin change int pins are the same as int pins ?
Thanks a lot.
Dibor
PostPosted: Sun Mar 26, 2006 7:06 am    Post subject: Reply with quote
Hello
Try to use Mega32
Has 3 external int. pins
CUL
View user's profile MSN Messenger
i.dobson
PostPosted: Sun Mar 26, 2006 6:14 pm    Post subject: Reply with quote
You actually need 1 interupt and 2 external counters.
You could use a mega32 with the 2 flowmeters connected to T0 & T1 (portb.0 & 1). For the flow meters all you need to do is count the number of pulses over a fixed period of time.
The TCP/IP module could be connected to INT0 (portD.2).
Why not use I2C for TCP/IP, it uses fewer pins if that helps.
Regards
Ian Dobson
