24VAC to 12VDC Power Supply
51Magnum
PostPosted: Sun Feb 04, 2007 1:05 am    Post subject: 24VAC to 12VDC Power Supply Reply with quote
Can someone please help?
I have a transformer that takes 120VAC to 24VAC. I need 12VDC at about 500mA. My problem is if I use a bridge rectifier and some smoothing caps I can get a good DC voltage of 38VDC. this is right on the edge for most voltage regs. How can I reduce this voltage? I know I can get a 60v max voltage reg but the problem is the heat. It dissipates so much heat. Is there a was to reduce the DC voltage out of the voltage reg?
Estelles
PostPosted: Mon Feb 05, 2007 5:50 pm    Post subject: Reply with quote
It all depends on the power you need. You can always use a switch voltage regulator. Most of them come with schematic examples:
http://www.onsemi.com/pub/Collateral/MC34063A-D.PDF
You also can use a MOSFET to chop off part of the AC you don't want.
What are your requirements?
Ed
51Magnum
PostPosted: Tue Feb 06, 2007 12:15 am    Post subject: Reply with quote
I am using a switching reg right now and it works well. Just kind of seems like overkill.
I need 12vdc at 500-800mA.
I am interested in the MOSFET idea. Do you have an example?
Estelles
PostPosted: Tue Feb 06, 2007 10:14 am    Post subject: Reply with quote
HI
Have a look at the attached file. The Mosfet disconnects whenever the voltage goes above the value set by the zener. You may need to change resistor values as this desing is for a high input voltage. Also the MOSFET is quite overkill, maybe something smaller would do it.
Let me know if you need any more info on how the chopper works?
Ed
Estelles
PostPosted: Tue Feb 06, 2007 10:18 am    Post subject: Reply with quote
Just a quick note, if you set the zener value too low, lets say 12 Vdc, you may find the the're is not enough current. I would advaise you to set it just below the voltage you need and use maybe 2 x 220uF caps at the output.
You may need a blocking diode if you are not using a voltage regulator at the output.
You could regulate it with a simple zener at the output but it all depends on how stable you want the PSU.
Hope it helps
