acatano
Posted: Thu Sep 09, 2004 6:11 pm Post subject: help on proper usage of "open file for input as binary& |
I need help on how to open a binary file for input.
Specifically BMP files. |
oe9vfj
Joined: 17 Jun 2004 Posts: 269 Location: Austria, Hard
Posted: Fri Sep 10, 2004 9:03 am Post subject: |
Here a small example:
Code: |
Dim b1 as Byte
Open "Test.bmp" for Binary as #10
If gbDOSError = 0 then
While eof(10) = 0
Get #10, b1
Print chr(b1) ;
Wend
Close #10
Else
Print "Can not open file Test.bmp"
Print "Error: " ; gbDOSError
End IF
_________________ regards Josef
DOS - File System for BASCOM-AVR on http://members.aon.at/voegel |
acatano
Posted: Sat Sep 11, 2004 3:11 am Post subject: Re:open file for input as binary |
When I compile your little program, I received several error messages.
gbDOSError is an invalid data type
End If If then expected.
There is something missing?
I am using a m128 |
oe9vfj
Posted: Sat Sep 11, 2004 6:31 pm Post subject: |
This was only the part to handle a file in binary mode.
You need a driver for the Stoarage medium (Compact-Flash, MMC-Card, Hard-Disk ...) and AVR-DOS. AVR-DOS is a library, which provides a file-system to BASCOM-AVR.
Please check [url]http://members.aon.at/voegel [/url]
for more information or the BASCOM-AVR Help file section Libraries-AVR-DOS.
In the section Download, you get all the additional files you need for the following Example:
Code: |
$Baud = 9600
Open "Com1:" as Binary as #1 ' use #1 for fs_interpreter
Config Clock = soft
enable interrupts
Config Date = MDY , Separator = .
Dim bTemp1 as Byte
print #1 , "Wait for Drive"
' Include here you driver for Compactflash/HardDisk or other
$Include "Config_CompactFlash_M128.bas" ' Does drive init too
If gbDriveError = 0 then
' Include AVR-DOS Configuration and library
$Include "Config_AVR-DOS.BAS"
Print #1 , "Init File System ... ";
bTemp1 = InitFileSystem(1) ' Partition 1
' use 0 for drive without Master boot record
if bTemp1 <> 0 then
print #1 , "Error: " ; bTemp1 ; " at Init file system"
else
print #1 , " OK"
print #1 , "Filesystem: " ; gbFileSystem
print #1 , "FAT Start Sector: " ; glFATFirstSector
Print #1 , "Root Start Sector: " ; glRootFirstSector
Print #1 , "Data First Sector: " ; glDataFirstSector
Print #1 , "Max. Cluster Nummber: " ; gwMaxClusterNumber
Print #1 , "Sectors per Cluster: " ; gbSectorsPerCluster
Print #1 , "Root Entries: " ; gwRootEntries
Print #1 , "Sectors per FAT: " ; gwSectorsPerFAT
Print #1 , "Number of FATs: " ; gbNumberOfFATs
end if
Else
Print #1 , "Error during Drive Init: " ; gbDriveError
end
End if
Dim b1 as Byte
While eof(10) = 0
Get #10, b1
Print chr(b1) ;
Wend
Close #10
Else
End IF
good luck _________________ regards Josef
acatano
Posted: Sat Sep 11, 2004 7:05 pm Post subject: Re:help on proper usage of "open file for input as bina |
I should have been more specific in my request.
I need to open a binary file (*.BMP) which I created and resides in one my hard disk directories, no CF or MMC cards drives. |
