Joined: 17 May 2004 Posts: 7 Location: Bellingham, wa usa
Posted: Tue Sep 07, 2004 2:54 pm Post subject: mega 128 timer0
i want to use timer0 and its output compare register, however when i try to use:
on compare0 dosomething
the erro code comes back as invalid interrupt
also i noticed that i can't write to the ouput compare register directly using the name that's in the m128.def file, as it comes back with an error.
i have written to the registor directly using the out command and giving the physical address of the register. but i still need to use interrupt from it
Posted: Wed Sep 15, 2004 8:24 pm Post subject:
yep i found that oco for the interrupt and ocro for the output compare registor were what i needed, after scanning the m128 dat file. thanks for the suggestion.
hopefully the next version of bascom will have hardware twi support in it
