snipsnip
Posted: Mon Feb 19, 2024 11:38 pm Post subject: Fuzzy Yacht Autopilot |
I know this is a forum for working code, and this is very much a work in progress, Sorry
Thought Id share a simple triangle membership function I'm working on. Just in case I'm way off course with all this.
Eventually - the aim is to have a simple feedback system to auto tune these arrays. I've still got a heap of work to do on it first.
Just looking for ideas on what people have done before.
Cheers
Code: |
'/ #tuneable
call BuildHeadingDeviationMember(1,25,20,70,50,100)
call BuildROCMember(1,49,40,60,51,100)
headingDeviation = 20 '/the error input value, map to 100 and peg extremes
fuzzyDeviation(1)=good(HeadingDeviation)
fuzzyDeviation(2)=nominal(HeadingDeviation)
fuzzyDeviation(3)=shit(HeadingDeviation)
ROC = 50 '/ degs/sec input mapped to 0 to 100 for normal range - peg extremes
fuzzyROC(1)=Slow(ROC)
fuzzyROC(2)=Average(ROC)
fuzzyROC(3)=Fast(ROC)
sub BuildHeadingDeviationMember(byval goodstart as byte,byval goodend as byte,byval nominalstart as byte, byval nominalend as byte,byval shitstart as byte, byval shitend as byte)
local tmp as single ,tmp1 as single,tmp2 as single,tmp3 as single
local angle as single, yaxis as single
local base as byte ,t as byte, ctr as byte
''/-good-
tmp1 = 100/goodend : angle = atn(tmp1) '/ RAD
base = goodend
for t = 0 to 100
if base < goodend then yaxis = base * TAN(ANGLE)
if base > goodend then yaxis = 0
Good(t) = int(yaxis)
decr base
next t
''/-nominal-
tmp1 = nominalend - nominalstart: tmp1=tmp1 / 2 :ctr = tmp1 + nominalstart
tmp2 = 100/tmp1 : angle = atn(tmp2)
base = 0
for t = 1 to ctr
if t < nominalstart then yaxis = 0
if t > nominalstart then yaxis = base * TAN(ANGLE)
nominal(t) = int(yaxis)
if t => nominalstart then incr base
next t
base = NominalEnd - ctr
for t = ctr to 100
if t > NominalEnd then yaxis = 0
if t < NominalEnd then yaxis = base * TAN(ANGLE)
Nominal(t) = int(Yaxis)
if t =< NominalEnd then decr base
next t
''/-shit-
tmp = 100 - ShitStart
tmp1 = 100 / tmp : angle = atn(tmp1)
base = tmp
for t = 100 to 0 step -1
if base < ShitStart then Yaxis = base * TAN(angle)
if base > GoodEnd then yaxis = 0
shit(t) = int(yaxis)
decr base
next t
end sub
Posted: Tue Feb 20, 2024 8:31 pm Post subject: |
thanks for sharing. I have no experience with this but i am sure it is of interest to others. lets see _________________ Mark |
Per Svensson
Joined: 03 Oct 2004 Posts: 235 Location: Gothenburg, Sweden
Posted: Wed Feb 21, 2024 1:36 pm Post subject: |
Hi Snipsnap,
I worked on an autopilot for my 10m sailboat some years ago.
Unfortunately I can not guide you along the Fuzzy road as I know nothing about it. Mine was based in PID.
I learnt that finding the right control parameters is virtually impossible as the conditions (wind, waves, tilt) is changing with weather
so much that they must be dynamically controlled all the time. Perhaps fuzzy can do this?
Mine worked fine in decent conditions, but had problem with stability when sea got rough.
I have worked all my life with inertial sensors, so getting the indata is not a problem. The challenge is to trim the gains.
If I would do this again today, I would certainly look at artificial intelligence
Good luck
/Per |
snipsnip
Posted: Wed Feb 21, 2024 2:45 pm Post subject: |
Per Svensson wrote: | Hi Snipsnap,
Good luck
/Per |
Hi mate, you inspired me to look into this with your Kalman filter imu examples. They were a bit too full on for me to get my head around and adapt to a pilot though. At least with fuzzy, while still a bit complicated - the maths is easy to understand and tweak. (from what I have gathered so far)
Re - changing conditions... There's only so many member functions and resulting lookup tables that can fit into a little avr memory.
still though, from what I've read so far it should be ok. (as long as the model is close, this is the very hard bit imo) No complex maths involved to build it, just intuition or a heap of data. I'm only doing this for fun - but if I can get something workable, i'll ditch the current tiller pilot and run it.
Cheers mate. |
Per Svensson
Posted: Wed Feb 21, 2024 3:16 pm Post subject: |
By the way...
I did try an simple type of AI for PID parameter optimisation when I was up to it.
I tried a method called "Genetic Algorithms". It is a technique that mimics the natural evolution of life
You know - "Evolution always finds a way" You can read more about it here if you like.
https://se.mathworks.com/help/gads/what-is-the-genetic-algorithm.html
The result was rather poor though. Not because the method is bad, but because the training is hard.
I really never found an automated way to describe to the system what a good boat steering should look like.
The method demands a repetitive "Steer the boat using trained parameters" . Then "Check if things have improved
with these new parameters compared to a previous set of params ". Then "Generate a set of parameters including some randomness"
Then test each new candidate and kill those that performed worst. Then breed last good known set with this new candidate...
Etc... etc... over and over until evolution finds an optimum set of params..
Well - In theory it works, but hard to find a selection criteria.
Modern AI is using smarter algorithms
/Per |
snipsnip
Posted: Fri Feb 23, 2024 1:22 am Post subject: |
This is the basic outline of what I'm looking to implement..
https://www.youtube.com/watch?v=TReelsVxWxg
Go to around the 50 min mark for the nitty gritty
I'll be using something like these below as member functions fed from a BNO085 imu and gps
heading deviation
rate of change in heading
speed of boat
acceleration of boat [x,y,z] axis
the (looped through) combination of these will then generate a lookup table / array with the steering output.
any tuning change and the table will need to be regenerated. I don't think the avr could do the calcs live.
Hopefully this should be enough to judge sea state and spit out a decent rudder angle / rate command to suit. |
snipsnip
Posted: Mon Mar 04, 2024 12:01 pm Post subject: |
Here's where I'm at with the rule / inference block.
Code: |
''/ -------------heading error / accel get merged and defuzzed to produce rudder rate of change---------------
''/ HeadingDeviation aka error = value returned from navigation function #wip
HeadingDeviation = byteMap(V,0,30,0,100) '/ crisp input, replace v with input
'/ HOLDS THE % VALUES EACH MEMBER FUNCTION
FuzzyDeviation(1) = Good(HeadingDeviation)
FuzzyDeviation(2) = Nominal(HeadingDeviation)
FuzzyDeviation(3) = Shit(HeadingDeviation)
''/Accel is a value of "seastate" returned from a function that either merges, normalise or maxes imu accel x,y,z outputs?
Accel = byteMap(V,0,30,0,100)' #test
FuzzyAccel(1) = Calm(accel)
FuzzyAccel(2) = Choppy(accel)
FuzzyAccel(3) = Ruff(accel)
'/convert input member functions to a 1,2,3 definition. 1=L 2=M 3=H
Max(Fuzzydeviation(1), dev_val, dev_mem) '/ ###_mem is the index # of the highest value of the fuzzy array
Max(FuzzyAccel(1), sea_val, sea_mem) '/ ###_val is the value of the highest value of the array
'/ MERGE RULES - THIS DECIDES WHICH RUDDER RATE OUTPUT MEMBER FUNCTION GETS LOADED
if Dev_Mem = 3 and Sea_Mem= 3 then OP_MF= 3
if Dev_Mem = 3 and Sea_Mem= 2 then OP_MF= 3
if Dev_Mem = 3 and Sea_Mem= 1 then OP_MF= 2
if Dev_Mem = 2 and Sea_Mem= 3 then OP_MF= 2
if Dev_Mem = 2 and Sea_Mem= 2 then OP_MF= 1
if Dev_Mem = 2 and Sea_Mem= 1 then OP_MF= 1
if Dev_Mem = 1 and Sea_Mem= 3 then OP_MF= 2
if Dev_Mem = 1 and Sea_Mem= 2 then OP_MF= 3 '/ high here as this is where the control should home in on
if Dev_Mem = 1 and Sea_Mem= 1 then OP_MF= 3 '/ and once in this region we want fast response to keep it there????
'/ load the mf values into an array for the MF_height to work with
select case OP_MF
case 1:'/ lo value MF
if dev_val > sea_val then
MF_height(1) = dev_val
MF_height(2) = sea_val
MF_height(3) = 0
else
MF_height(1) = sea_val
MF_height(2) = dev_val
MF_height(3) = 0
end if
case 2:'/ med value MF
if dev_mem > sea_mem then '/ not a typo re:- the mem
MF_height(3) = 0
else
MF_height(1) = 0
MF_height(3) = dev_val
end if
'/ ^this is garbage, need a better way.
case 3:'/ hi value MF
MF_height(1) = 0
else
MF_height(1) = 0
MF_height(3) = sea_val
end if
end select
'/MERGE the three defuzz member triangles into one array with heights capped as per above
for n=1 to 100
if HeadAccel_Low_Defuzz(n) >= MF_height(1) then HeadAccel_merged_Defuzz(n) = MF_height(1)
if HeadAccel_med_Defuzz(n) >= MF_height(2) then HeadAccel_merged_Defuzz(n) = MF_height(2)
if HeadAccel_hi_Defuzz(n) >= MF_height(3) then HeadAccel_merged_Defuzz(n) = MF_height(3)
next n
Per Svensson
Posted: Mon Mar 04, 2024 5:11 pm Post subject: |
Hi Snipsnip
I followed the lecture to get some understanding of the Fuzzy control principle, and found it very amusing (or how I should put it..)
The Fuzzification part is straightforward (well, rather straightforward) But to generate the rules is really another story.
Interesting to see that the lecturer suggested Genetic Algo since this is something I can understand. But also know is hard to adopt.
And not only hard to adopt, but also to evaluate the result of, because the convergence is usually there, but often the found solution is not the maximum,
but a LOCAL maximum, which easily could fool you to believe you have found a decent solution, whilst we in reality have a poor solution.
Anyway, he also suggests other solutions, and especially evolutionary methods sounds interesting, so I will follow that track and listen to his next lecture too.
I guess you have already don that?
By the way. How do one know if a set of rules will generate a stable fuzzy output (Not causing oscillations etc). Are there stability criterias?
/Per |
snipsnip
Posted: Mon Mar 04, 2024 10:27 pm Post subject: |
Per Svensson wrote: | Hi Snipsnip
/Per |
Yeah. the rules part had me scratching my head for a very long time. Just trying to understand the concept and how and why it links everything.
re - local maximums and other methods... Thats the crazy part with this fuzzy stuff, literally every single thing is tuneable, everything!
I have no idea how well this implementation will work - if at all. <- i think i understand it and what's going on, I could be way off??
If stability is an issue I can add some more member functions around the oscillation points, but the logic rules can get big pretty quick with more MF's.
I was hoping and thinking if the rule block is assigned properly - stability should be inherent. ? I put some comments on the rule blocks (above) where I think these areas will be.
I have almost enough of a program now to loop through the entire input ranges and generate the output tables. I'll post the surface plots when I get it all working.
I think a genetic algorithm would work very well with this - but jesus - I'm struggling just getting my head around this, let alone another even more complex layer on top. |
Per Svensson
Posted: Mon Mar 04, 2024 11:11 pm Post subject: |
https://www.youtube.com/watch?v=3-NiZPbkr7A
That guy is a good teacher. rather funny too, certainly know what he is talking about
I got a good recap of GA which was good since I have not been into it since 2011.
If you are interested in a thread I started about Genetic Algorithms you can have a look here:
https://www.mcselec.com/index2.php?option=com_forum&Itemid=59&page=viewtopic&t=9274&highlight=genetic
The reason why I gave it up was that it was so slow to train the GA population , and also hard to find a fitness criteria.
Training each generation requires that you have to run the real process (the boat) for some minutes to se how well it behaves with the selected genome
and then from the fitness results generate another population via Crossover, cloning and mutation.
Running hundreds of evaluations take an awful lot of time. In addition it is not easy to maintain a reasonably consistent sea state for such a long time:
I would take a very long journey to get a result.
Fuzz logic is a new world for me although I have seen it around for many years, but really never taken the time to dig into it. But very interesting
The mathematical simplicity is very tempting. But on the other hand Kalman Filter math is also very simple, but not so easy to grasp and digest so somplicity
can be very deceiving.
/P
[/url] |
snipsnip
Posted: Tue Mar 05, 2024 12:16 am Post subject: |
Thanks for that, very interesting thread. a shame it's locked.
The way fuzzy works with sets should be well suited for a genetic algorithm to tune and test?
Now I want to see if I can implement that can of worms. Thanks! |
