enniom
Posted: Mon Feb 20, 2023 4:57 pm Post subject: Xmega 8/16/32E5 - Solved PWM |
The datasheet for the E5 series does show that PWM signals can be output directly to pins on PORTs C and D.
However, the current BASCOM compiler does not appear to have this function. Instead, this work-around was proposed in the samples:
Code: | $regfile = "xm32e5def.dat"
$crystal = 32000000 '32MHz
$hwstack = 64
$swstack = 40
$framesize = 40
Config Osc = Enabled , Pllosc = Enabled , Pllmul = 10
Config Portd.4 = Output ' leds on the prototyep boards
Config Portd.5 = Output
Config Tcc4 = Pwm , Prescale = 1024 , Capmodeah = Both_enabled
Tcc4_per = 5000 ' set blink frequence
Tcc4_cca = 4990 ' set led on start time
On Tcc4_ovf Tc4_isr ' interrupt when count = period
On Tcc4_cca Myisr ' interrupt when timer = compare (CCA)
Enable Tcc4_ovf , Lo 'Enable overflow interrupt in LOW Priority
Enable Tcc4_cca , Lo 'Enable overflow interrupt in LOW Priority
!nop
End 'end program
'--------------------[Interrupt Service Routines]-------------------------------
Tc4_isr: ' overflow interrupt
Toggle Portd.4 ' change status led D4
Set Portd.5 ' led D5 is Off (ON by pull-down)
Tcc4_intflags.0 = 1 ' clear interrupt flag
Myisr:
Reset Portd.5 ' led D5 is OFF(off by pull-down)
Return |
It seems the configuration statement CONFIG TCC4 = PWM ... etc., does not have any effect on the relevant registers. Test code is shown here:
$hwstack = 127
$swstack = 127
$framesize = 127
$crystal = 32000000
Config Osc = Disabled , 32mhzosc = Enabled 'internal 2 MHz and 32 MHz enabled
Config Sysclock = 32mhz , Prescalea = 1 , Prescalebc = 1_1 'use 32 MHz
'Soft UART
Open "COMD.6:57600,8,N,1" For Output As #2
' PWM Test - original
Config Portc = Output
'Config Tcc4 = Pwm , Prescale = 1024 , Capmodeah = Cap_enabled
Config Tcc4 = Pwm , Prescale = 1024 , Capmodeah = Comp_enabled
'Config Tcc4 = Pwm , Prescale = 1024 , Capmodeah = Both_enabled
'Changes to the CONFIG does not change the values of the Registers shown below.
Start TCC4 'Not needed or no function??
Tcc4_per = &HFFFF
Tcc4_cca = &H8000
Tcc4_ccb = &H8000
Tcc4_ccc = &H8000
Tcc4_ccd = &H8000
Print #2 , "PORTC Registers"
Print #2 , "==============="
Print #2 , "PORTC_REMAP " ; Bin(portc_remap)
Print #2 , "TCC4_CTRLA " ; Bin(tcc4_ctrla)
Print #2 , "TCC4_CCABF " ; Bin(tcc4_ccabuf)
Print #2 , "TCC4_CTRLB " ; Bin(tcc4_ctrlb)
Print #2 , "TCC4_CCBBF " ; Bin(tcc4_ccbbuf)
Print #2 , "TCC4_CTRLC " ; Bin(tcc4_ctrlc)
Print #2 , "TCC4_CCCBF " ; Bin(tcc4_cccbuf)
Print #2 , "TCC4_CTRLD " ; Bin(tcc4_ctrld)
Print #2 , "TCC4_CCDBF " ; Bin(tcc4_ccdbuf)
Print #2 , "TCC4_CTRLE " ; Bin(tcc4_ctrle)
Print #2 , "TCC4_CTRLF " ; Bin(tcc4_ctrlf)
Print #2 , "TCC4_CTRLGS " ; Bin(tcc4_ctrlgset)
End |
No output is created on PORTC0...3.
However, the datasheets suggests that the CTRLE register must be set.
$hwstack = 127
$swstack = 127
$framesize = 127
$crystal = 32000000
'Soft UART
' PWM Test - Solution
'Config Tcc4 = Pwm , Prescale = 1024 , Capmodeah = Cap_enabled ', Comparea = Enabled
Config Tcc4 = Pwm , Prescale = 1024 , Capmodeah = Comp_enabled ', Comparea = Enabled
'Config Tcc4 = Pwm , Prescale = 1024 , Capmodeah = Both_enabled ', Comparea = Enabled
Tcc4_per = &HFFFF
Tcc4_cca = &H8000
Tcc4_ccb = &H8000
Tcc4_ccc = &H8000
Tcc4_ccd = &H8000
Tcc4_ctrle = &B01010101
End |
This creates the proper output on PORTC0...3.
Also, the output can be moved to PORTC4...7 by using the REMAP Register:
Code: | Portc_remap = &B000_0_1111 |
Notes:
1) The Start TCC4 command does NOT seem to have any function?
2) Did not test TCC5.
E |
cyklop1977
Posted: Tue May 16, 2023 9:37 am Post subject: |
It is same result for:
PWM
CONFIG TCC4 = PWM , PRESCALE = 64 , CAPMODEAL = COMP_ENABLED , CAPMODEBL = COMP_ENABLED , CAPMODECL = COMP_ENABLED , CAPMODEDL = COMP_ENABLED , RESOLUTION = 16
and FREQ
CONFIG TCC4 = FREQ , PRESCALE = 1 , CAPMODEAL = COMP_ENABLED , CAPMODEBL = COMP_ENABLED , CAPMODECL = COMP_ENABLED , CAPMODEDL = COMP_ENABLED , RESOLUTION = 16 |
