syndetic1
Posted: Tue Jan 24, 2023 8:14 am Post subject: Where does the bootloader erase EEPROM |
I have the bootloader working but it is erasing the EEPROM.
to my knowledge I am not sending EEPROM information.
I want to just send the program so that calibration settings can remain in EEPROM.
There are bits of the bootloader that I don't understand for example, where and how does it erase the EEPROM?
Thanks,
(BASCOM-AVR version : 2.0.8.5 ) |
Posted: Tue Jan 24, 2023 8:56 am Post subject: Re: Where does the bootloader erase EEPROM |
syndetic1 wrote: | I have the bootloader working but it is erasing the EEPROM. |
Ah, yes, THE bootloader.
Generally: Did you check about the EESAVE fuse bit?
In detail, supply information about:
- type of MCU
- make/type of loader, Bascom-one? If yes, attach the Bascom source you've used.
- software interface, Bascom GUI or other? |
syndetic1
Posted: Wed Jan 25, 2023 2:06 am Post subject: Where does the bootloader erase EEPROM |
Thank you for your reply.
I am using a Mega128
I am programming from within BASCOM and also I bought the Bascom stand alone uploader.
Both behave the same way.
The boot loader is essentially the Bascom one. I have taken out lines pertaining to other CPUs. I have added in a delay that jumps to the users program if the uploader does not start to send new code. Listing below.
I don't understand which line actually erases the EEPROM.
In response to the earlier response,
Fuse Byte High controls the boot loader. I had it set as follows:
1101 1000 = Hex D8
Bit 0 BOOTRST = 0 means the micro boots into the boot loader.
Bit 3 -> EESAVE 1=EEPROM Erased with chip erase and 0 means dont erase with chip erase.
As I am programming using the boot loader, I am not using an external programmer to issue a chip erase but obviously the boot loader can erase the Flash and the EEPROM.
I was not sure whether Fuse Byte High bit 3 is involved with the boot-loader memory erase so I change bit 3 to zero.
Fuse Byte High is now D0
Then I set some EEPROM locations to non zero values and reload my firmware using the boot loader.
Upon checking, I see that the EEPROM is all zero again.
I do not think EESAVE affects in system programming.
Code: |
' (c) 1995-2020, MCS
' Bootloader.bas
' This sample demonstrates how you can write your own bootloader
' in BASCOM BASIC
' VERSION 2 of the BOOTLOADER. The waiting for the NAK is stretched
' further a bug was resolved for the M64/M128 that have a big page size
'V1-3 3-OCT-2022 Frank Thomson
' Added a timeout of 10 seeconds after which it jumps to the user program
'| 7 | 6 | 5 | 4 | 3 | 2 | 1 | 0 |
'| SPMIE | RWWSB | SIGRD | RWWSRE | BLBSET | PGERS | PGERS | SPMEN |
' This bit enables the SPM instruction for the next four clock cycles.
' check for previous SPM complete
$hwstack = 40
$swstack = 40
$framesize = 40
$crystal = 8000000
$baud = 9600 'this loader uses serial com
'It is VERY IMPORTANT that the baud rate matches the one of the boot loader
'do not try to use buffered com as we can not use interrupts
$regfile = "m128def.dat"
Const Loaderchip = 128
' Mega128
$loader = &HF000 ' 1024 words
Const Maxwordbit = 7 'Z7 is maximum bit '
'MAXWORDBIT value, how to determine it?
'Maxwordbit should have the same value as the maximum Z bit.
'For Example , For The M88 the PDF Shows Pcword : Pc[4 : 0] And Z Value Z5 : Z1.
' In That Case The Maximum Bit is Z5 , Thus Bit 5 , Meaning Maxwordbit Is 5.
Const Maxword =(2 ^ Maxwordbit) * 2 '128
Const Maxwordshift = Maxwordbit + 1
'Dim the used variables
Dim Bstatus As Byte , Bretries As Byte , Bblock As Byte , Bblocklocal As Byte
Dim Bcsum1 As Byte , Bcsum2 As Byte , Buf(128) As Byte , Csum As Byte
Dim J As Byte , Spmcrval As Byte ' self program command byte value
Dim Z As Long 'this is the Z pointer word
Dim Vl As Byte , Vh As Byte ' these bytes are used for the data values
Dim Wrd As Word , Page As Word 'these vars contain the page and word address
Dim Bkind As Byte , Bstarted As Byte
Dim ExitDelayCounter as Long
ExitDelayCounter = 500000
Disable Interrupts 'we do not use ints
'Waitms 100 'wait 100 msec sec
'We start with receiving a file. The PC must send this binary file
'some constants used in serial com
Const Nak = &H15
Const Ack = &H06
Const Can = &H18
$timeout = 400000 ' Used by the waitkey statement that we are trying to get rid of
'we use some leds as indication in this sample , you might want to remove it
'Config Pinb.2 = Output
'Portb.2 = 1 'the stk200 has inverted logic for the leds
'Config Pinb.3 = Output
'Portb.3 = 1
Print "M128 Boot Loader V1.3"
Bretries = 5 'we try 5 times
Testfor123:
Do ' As at Ver 1-3 3-10-2022 Replaced Waitkey with Inkey
if ExitDelayCounter > 0 Then
Decr ExitDelayCounter
else
' Hit zero - Goto User Program
Print "LOADER Timeout - Jumping to User Program"
Goto _reset
End if
Bstatus = Inkey()
If Bstatus = 123 Then 'did we received value 123 "{" ?
If Bretries > 0 Then
Decr Bretries
Else
Print Chr(bstatus);
Goto Loader ' yes so run bootloader
Elseif Bstatus = 27 Then '<ESC>
Print "Jumping to User Program at 0"
Goto _reset 'goto the normal reset vector at address 0
'End If
Elseif Bstatus = 13 Then ' <cr>
Print "LOADER Press ESC to Exit"
'this is the loader routine. It is a Xmodem-checksum reception routine
Loader:
Bstatus = Waitkey()
Loop Until Bstatus = 0
' Frank: Not usig Portb.2 LED
'For J = 1 To 3 'this is a simple indication that we start the normal reset vector
' Toggle Portb.2 : Waitms 50
'Next
If Bkind = 0 Then
Spmcrval = 3 : Gosub Do_spm ' erase the first page
Spmcrval = 17 : Gosub Do_spm ' re-enable page
Bretries = 10 'number of retries
Bblocklocal = 1
Bstarted = 0 ' we were not started yet
Csum = 0 'checksum is 0 when we start
Print Chr(nak); ' firt time send a nack
Bstatus = Waitkey() 'wait for statuse byte
Select Case Bstatus
Case 1: ' start of heading, PC is ready to send
Csum = 1 'checksum is 1
Bblock = Waitkey() : Csum = Csum + Bblock 'get block
Bcsum1 = Waitkey() : Csum = Csum + Bcsum1 'get checksum first byte
For J = 1 To 128 'get 128 bytes
Buf(j) = Waitkey() : Csum = Csum + Buf(j)
Bcsum2 = Waitkey() 'get second checksum byte
If Bblocklocal = Bblock Then 'are the blocks the same?
If Bcsum2 = Csum Then 'is the checksum the same?
Gosub Writepage 'yes go write the page
Print Chr(ack); 'acknowledge
Incr Bblocklocal 'increase local block count
Else 'no match so send nak
Print Chr(nak);
Else
Print Chr(nak); 'blocks do not match
Case 4: ' end of transmission , file is transmitted
If Wrd > 0 And Bkind = 0 Then 'if there was something left in the page
Wrd = 0 'Z pointer needs wrd to be 0
Spmcrval = 5 : Gosub Do_spm 'write page
' Waitms 100 ' OPTIONAL REMARK THIS IF THE DTR SIGNAL ARRIVES TO EARLY
Print Chr(ack); ' send ack and ready
Portb.3 = 0 ' simple indication that we are finished and ok
Waitms 20
Goto _reset ' start new program
Case &H18: ' PC aborts transmission
Goto _reset ' ready
Case 123 : Exit Do 'was probably still in the buffer
Case 124 : Exit Do
Case Else
Exit Do ' no valid data
End Select
If Bretries > 0 Then 'attempte left?
Waitms 1000
Decr Bretries 'decrease attempts
Else
Goto _reset 'reset chip
'write one or more pages
Writepage:
If Bkind = 0 Then
For J = 1 To 128 Step 2 'we write 2 bytes into a page
Vl = Buf(j) : Vh = Buf(j + 1) 'get Low and High bytes
R0 = Vl 'store them into r0 and r1 registers
R1 = Vh
Spmcrval = 1 : Gosub Do_spm 'write value into page at word address
Wrd = Wrd + 2 ' word address increases with 2 because LS bit of Z is not used
If Wrd = Maxword Then ' page is full
Page = Page + 1 'next page
Spmcrval = 3 : Gosub Do_spm ' erase next page
Else 'eeprom
For J = 1 To 128
Writeeeprom Buf(j) , Wrd
Wrd = Wrd + 1
'Toggle Portb.2 : Waitms 10 : Toggle Portb.2 'Frnk: Deleted. indication that we write
' The SPMEN bit will auto-clear upon completion of an SPM instruction
' Bitwait address until 0
Do_spm:
' Wait until Spmcsr.0 is zero
Bitwait Spmcsr.0 , Reset ' check for previous SPM complete
Bitwait Eecr.1 , Reset 'wait for eeprom
Z = Page 'make equal to page
Shift Z , Left , Maxwordshift 'shift to proper place
Z = Z + Wrd 'add word
! lds r30,{Z}
! lds r31,{Z+1}
#if _romsize > 65536
!lds r24,{Z+2}
!sts rampz,r24 ' we need to set rampz also for the M128
#endif
Spmcsr = Spmcrval 'assign register
! spm 'this is an asm instruction
! nop
! nop
'How you need to use this program:
'1- compile this program
'2- program into chip with sample elctronics programmer
'3- select MCS Bootloader from programmers
'4- compile a new program for example M88.bas
'5- press F4 and reset your micro
' the program will now be uploaded into the chip with Xmodem Checksum
' you can write your own loader.too
'A stand alone command line loader is also available
'How to call the bootloader from your program without a reset ???
'Do
' Print "test"
' Waitms 1000
' If Inkey() = 27 Then
' Print "boot"
' Goto &H1C00
' End If
'Loop
'The GOTO will do the work, you need to specify the correct bootloader address
'this is the same as the $LOADER statement.
[/code] |
Posted: Wed Jan 25, 2023 3:41 pm Post subject: |
I don't see an chip erase either, but I would not exclude such idea, especially if it does not cost me anything more than attaching an ISP and flipping EESAVE to 0.
You did use the original loader, removed some bones while leaving others in:
Code: | Else 'eeprom
For J = 1 To 128
Wrd = Wrd + 1
End If |
This code normally writes the EEProm.
I would remove it or at least put a print for debug info in it, to watch if it is accessed nonetheless.
In case it is, this hints to something seriously going wrong.
Did you think about the possibility the Bascom interface sends a 124 plus EEProm data?
With the original loader no problem, as it knows how to handle it.
Your code however ignores the 124, but would compare following EEProm data against 123, this would jump to the loader-label.
Assume the sent EEProm data further contains a following zero, then it makes it already to line 115 of your code.
From there it's difficult to imagine what's happening, as things ran out of sync.
To solve this potential trap, I would leave in all the 124-related code and only remove/comment:
Code: | Writeeeprom Buf(j) , Wrd |
syndetic1
Posted: Tue Jan 31, 2023 11:03 pm Post subject: |
Thanks MWS,
Commented out Writeeeprom Buf(j) , Wrd and it worked. |
