bellon
Posted: Fri Jan 20, 2023 9:28 am Post subject: ESP8266 and GUI-O application |
Hello,
I installed the GUI-O application on my smartphone and managed to connect to my wiffi router. Now my application (an Arduino Nano board sends data to an ESP8266 V2) but I didn't quite understand how to connect ESP8266 V2 with my wiffi router to be able to display this data on the GUI_O application. (I was inspired by Matjazs' post on this forum. Thanks to him!
Thanks for your help !!
(BASCOM-AVR version : 2.0.8.5 , Latest : 2.0.8.5 ) |
plouf
Joined: 19 Jan 2012 Posts: 78 Location: Athens,Greece
Posted: Fri Jan 20, 2023 1:33 pm Post subject: |
gui-o has its own forums, there you should better more support for gui-o
https://forum.gui-o.com/ _________________ Christos |
matjazs
Posted: Fri Jan 20, 2023 3:36 pm Post subject: |
This example describes how the ESP8266 works as a bridge (serial 232 over WiFi/internet).
The best way to do this is to use the ESP8266 Wemos D1 mini module https://www.faranux.com/product/esp8266-esp-12-nodemcu-wemos-d1-mini-wifi-4m-bytes-development-board-module/,
because it contains a USB mini connector for programming and verification. Of course, any other ESP8266 can be used.
A simple method of preparing the module is described:
1. Download the Arduino IDE
2. Download ESP8266_GUI-O_pairing_libs.zip and extract the archive
3. Download ESP8266_GUI-O_pairing_source.zip and extract the archive
Details are described here in the section: Auto Pairing ESP8266 & Arduino & GUI-O
https://www.gui-o.com/examples
When the ESP is programmed, the blue LED flashes.
To pair, open the GUI-O app https://play.google.com/store/apps/details?id=com.guio.guioapp&pli=1 and go to Settings/Quick pair/Direct device paring/
find your module named guio_xxxxxxx running in AP mode (password is 12345678), follow the instructions to connect to your WiFi (SSD/password...)
When pairing is complete and the module is connected (the blue LED lights up constantly), for checking use the terminal emulator to verify and verify sending in both directions.
ESP8266 in this case works as serial (RS232) communication via WiFi/internet. In other words, the same if we use the bluetooth module f.e. HC06.
After that connect modul in your hardware on serial port (Tx Rx) and enjoy. |
bellon
Posted: Fri Jan 20, 2023 5:16 pm Post subject: |
Matjzas,
For more precision, my application is programmed with Bascom and not in C. I took over the one you posted on this forum. But my problem is the following: when I am in "Settings/Quick pair/Direct device paring/
I can't find the module named "guio_xxxxxxx" and when the app goes to wiffi, there is no guio_xxxxxxx. I must be missing something, but what?
Thank you for your dedication. Bernard |
matjazs
Posted: Mon Jan 23, 2023 8:30 am Post subject: |
Hello.
Here is my second explanation how you can prepare the ESP8266 for use in Bascom - with screenshots and comments. (GUI-O ESP8266 Preparation Bascom.pdf)
The Arduino *.ino and lib-i files are also attached.
I hope this helped.
I also suggest you send / show us screenshots of your Bascom / GUI-O app so we can see the result
1. Download Arduino and install it
https://www.arduino.cc/en/software
2. Unzip the file guio_esp8266.zip.
3. Open the guio_esp8266.ino file with Arduino.
4. Include the libraries in the Arduino
5. Compile and program the ESP8266.
All detailed explanations can be also found at
www.gui-o.com /examples
... in the section: Auto Pairing ESP8266 & Arduino & GUI-O
or forum:
https://forum.gui-o.com/ |
JC
Joined: 15 Dec 2007 Posts: 586 Location: Cleveland, OH
Posted: Mon Jan 23, 2023 7:54 pm Post subject: |
Wow!
Thank you!
JC |
bellon
Posted: Wed Jan 25, 2023 4:02 pm Post subject: |
Thank you very much, great job!!
Bernard |
bellon
Posted: Tue Feb 07, 2023 10:34 am Post subject: |
Hello Matjazs
I am not an Arduino IDE specialist but I try to follow the "ESP8266 & Arduino & GUI-O automatic pairing" procedure but when I compile the program I have the following message. A small idea?[img][/img] |
Posted: Tue Feb 07, 2023 11:20 am Post subject: |
All MCS forums must have a strong link to BasCom.
That does not seem to be the case here.
You best check the arduino forum or the guio forum. _________________ Mark |
