Dave
Posted: Fri Dec 09, 2022 5:17 pm Post subject: How to use RTC |
Hello.
I would like to configure the RTC (real time counter) to wakeup my program once a minute or maybe much longer.
Here is my test code. No interrupts so far. Any help would be appreciated.
Code: |
$regfile = "xm256A3Udef.dat"
$crystal = 32000000
$hwstack = 100
$swstack = 100
$framesize = 100
$lib "xmega.lib"
Config Osc = disabled , 32mhzosc = Enabled , 32khzosc = Enabled ,32KHZPOWERMODE=LOW_POWER
Config Priority = Static , Vector = Application , Lo = Enabled , Med = disabled , Hi = disabled
'pin33 PD7, TXD1 & pin32 PD6, RXD1 - bascom COM4.
Config Com4 = 115200 , Mode = Asynchroneous , Parity = None , Stopbits = 1 , Databits = 8
Open "Com4:" For Binary As #4
print #4,
print #4,version(3)
Config Clock = user
'Config Clock = Soft , Rtc = 1KHZ_INT32KHZ_RCOSC , gosub = SecTic
CLK_RTCCTRL=5 'value from config soft
print #4,"rtcctrl:";hex(CLK_RTCCTRL)
'bitwait RTC_STATUS.0,reset
RTC_PER=1024 'value from config soft
print #4,"PER:";RTC_PER
RTC_ctrl=1 'value from config soft 'prescale: 0=RTC stopped, 1=DIV1, 2=DIV2, 3=DIV8, 4=DIV16, 5=DIV64, 6=DIV256, 7=DIV1024
print #4,"ctrl:";rtc_ctrl
rtc_intctrl=1 'value from config soft 'lo pri interrupt
print #4,"intctrl:";rtc_intctrl
rtc_comp=0 'value from config soft '1024 '32768Hz
print #4,"comp:";rtc_comp
on RTC_OVF RTC_isr
enable RTC_OVF
'on RTC_CMP RTC_isr
'enable rtc_CMP
enable interrupts
do
loop
RTC_isr:
print #4,"*";
return
sectic:
print #4,"!";
return |
(BASCOM-AVR version : 2.0.8.5 )
enniom
Posted: Fri Dec 09, 2022 7:14 pm Post subject: |
Try it using soft clock.
Code: | '============================================
'Config SOFT Clock
Config Clock = Soft , Rtc = 1khz_int32khz_ulp, Gosub = Sectic 'select internal 1 KHz clock from the 32KHz internal oscillator
Rtc_ctrl = xxxxx
Sectic:
Print #4,"*"
Return |
ALSO, is there a reason you do not use,
Code: | $crystal = 32000000 ' or similar ????
Dave
Posted: Fri Dec 09, 2022 7:43 pm Post subject: |
hello enniom
Thanks for the reply.
Yes, I have used the soft clock and I can make it work with longer interrupts periods. The reason I would prefer to not use soft clock is that the soft clock ISR expects an interrupt once a second.
So I if I set up Rtc_ctrl for say 64 second interrupts the soft clock ISR results are wrong. I can correct for that in sectic but it's not very efficient. Where as with USER clock I would just need to add 64 to a long variable to keep track of the time. Or for applications that don't need time of day the RTC is the best chose for periodically waking the uC.
Quote: | $crystal = 32000000 |
I don't understand. I am using $crystal = 32000000. |
Dave
Posted: Sat Dec 10, 2022 11:21 pm Post subject: |
This is my latest attempt to get RTC interrupts. It still it's happening. I copied the settings of from config clock = soft settings.
All registers seem to read and write properly. I must be missing some register or something. What am I doing wrong?
Code: | $regfile = "xm256A3Udef.dat"
$crystal = 32000000
$hwstack = 100
$swstack = 100
$framesize = 100
$lib "xmega.lib"
print #4,
print #4,version(3)
Config Clock = user
on RTC_OVF RTC_OVF
enable RTC_OVF
'on RTC_CMP RTC_isr
'enable rtc_CMP
enable interrupts
do
loop
RTC_isr:
print #4,"*";
return
sectic:
print #4,"!";
return |
enniom
Posted: Sun Dec 11, 2022 1:19 am Post subject: |
The code you posted has both clock sources commented out.
This works for me:
Code: | $regfile = "xm192a3udef.dat"
$hwstack = 64
$swstack = 64
$framesize = 64
$crystal = 32000000
Config Osc = Disabled , 32mhzosc = Enabled , 32khzosc = Enabled
Config Porta.5 = Output 'red led
Dim I As Byte
For I = 1 To 8
Toggle Porta.5
Waitms 500
Wait 2
Config Clock = Soft , Rtc = 1khz_int32khz_rcosc , Gosub = Sectic
Bitwait Rtc_status.0 , Reset
Rtc_ctrl = &B0000_0011 'flash led every 8 sec
Sectic:
Toggle Porta.5 'led
Return |
Use Table 17.1 Prescaler to get the delay you want.
E |
Dave
Posted: Sun Dec 11, 2022 1:52 am Post subject: |
Quote: | The code you posted has both clock sources commented out. | Thanks for pointing that out. I fixed it.
I'll use soft clock if I can't get RTC working the way I hope.
Thanks. |
Dave
Posted: Sun Dec 11, 2022 5:14 pm Post subject: |
PROBLEM SOLVED (sort of)
So the problem seems to be that the statement "ON RTC_OVF RTC_isr " is not currently supported by bascom.
I've come up with a work around. Mark will problem get a laugh out of this. I created my first lib. It replaces the soft clock isr interrupt routine. See comments in code.
In this example the uC wakes up every 8 seconds and adds 8 to l_sys_sec, prints the new time and goes back to sleep. The sleep time can be up to 1024 seconds in this example.
$crystal = 32000000
$hwstack = 100
$swstack = 100
$framesize = 100
$lib "xmega.lib"
'For 32mhz clock.
Config Osc = disabled , 32mhzosc = enabled ,32khzosc = Enabled ,32KHZPOWERMODE=LOW_POWER
$lib "clock_bodge.lib"
'This is all there is in "clock_bodge.lib"
' [_SOFT_CLOCK]
' _Soft_clock:
' #IF _SECTIC = 1
' *@sectic
' #ENDIF
' Reti
' [END]
print #4,
print #4,version(3)
dim l_sys_sec as long
Config Clock = Soft , Rtc = 1KHZ_INT32KHZ_ULP , gosub = SecTic
RTC_ctrl=3 'prescale: 0=RTC stopped, 1=DIV1, 2=DIV2, 3=DIV8, 4=DIV16, 5=DIV64, 6=DIV256, 7=DIV1024
waitms 1
const c_sec_per_int=8
'on RTC_OVF RTC_isr '<-- This is currently not supported by Bascom.
'enable RTC_OVF
enable interrupts
do
Config Powermode = POWERSAVE
print #4,"time:";Time(l_Sys_Sec)
waitms 1 'some time to print.
loop
sectic:
l_sys_sec=l_sys_sec+c_sec_per_int
return
enniom
Posted: Sun Dec 11, 2022 5:25 pm Post subject: |
Dave,
Its difficult to understand the problem you are solving.
Is it to provide the capability to independently set the incremental value,
Code: | const c_sec_per_int=8
E |
Dave
Posted: Sun Dec 11, 2022 5:45 pm Post subject: |
enniom,
It's mostly about saving power in very lo power applications. As I tried to explain before, the problem is that soft clock expects an interrupt once a second. If you change the RTC to interrupt say every 8 seconds the time from soft clock will be garbage. Calling a routine that creates garbage every 8 seconds is a lot of wasted CPU time or wasted power over the course of several days. I can now use RTC to wake the uC once every n seconds instead of once a second. n can be up many hours or days for that matter. Does that make sense? |
enniom
Posted: Sun Dec 11, 2022 5:58 pm Post subject: |
Dave,
I don't think that's correct. This does exactly the same thing. Check the power consumption.
$hwstack = 64
$swstack = 64
$framesize = 64
$crystal = 32000000
Dim I As Byte
For I = 1 To 8
Toggle Porta.5
Waitms 500
Wait 2
Sectic:
Toggle Porta.5 'led
Return |
Dave
Posted: Sun Dec 11, 2022 6:16 pm Post subject: |
enniom,
Not really, print time$ after waking up the uC and you will see that it make no sense. |
enniom
Posted: Sun Dec 11, 2022 6:20 pm Post subject: |
Right. So you're after time not power consumption.
E |
enniom
Posted: Sun Dec 11, 2022 6:32 pm Post subject: |
Consider:
Code: | Dim L as Long
L = L+8
Print Time(L)
Loop |
E |
Dave
Posted: Sun Dec 11, 2022 6:36 pm Post subject: |
No, I'm trying to show you that your code is running an interrupt routine that is of little or no use. It's not a big effect. Running 80 or so line of assembly isn't much but your doing ever 8 seconds. Over time that adds up. Over the course of just one day that's 864000 lines of assemble code. |
enniom
Posted: Sun Dec 11, 2022 6:40 pm Post subject: |
OK.
RTC_ctrl=7 'prescale: 0=RTC stopped, 1=DIV1, 2=DIV2, 3=DIV8, 4=DIV16, 5=DIV64, 6=DIV256, 7=DIV1024
L = L+1024
Print Time(L)
Doesn't this wake up every 1024 seconds?
E |
