select case
loggercz
PostPosted: Sat Feb 12, 2022 9:54 am    Post subject: select case Reply with quote
when I use :
SELECT CASE X
CASE 1: X=2
CASE 2: X=1
END SELECT
Which value have X? Is only one line executed?
Thanks
Petr
(BASCOM-AVR version : 2.0.8.5 )
PostPosted: Sat Feb 12, 2022 10:37 am    Post subject: Reply with quote
This is what the Select Case is for. If value match with one compared then rest of code (compares) are skipped. Means "Goto End Select"
PostPosted: Sat Feb 12, 2022 11:39 am    Post subject: Reply with quote
Select case -----end select allows to go directly to the line corresponding to the requested value contrary to if-elseif__ elseif__ which tests all conditions
so in your example if X is 1 at the beginning it will take the value 2 before leaving the loop.
Can you specify your request?
JP Shocked
SZTRAD
PostPosted: Sat Feb 12, 2022 11:42 am    Post subject: Reply with quote
Petře
I'm sorry, but if I were you, I'd start here.
https://avrhelp.mcselec.com/
RS
loggercz
PostPosted: Sat Feb 12, 2022 6:53 pm    Post subject: Reply with quote
Because the program behaves strangely, I wondered if there was a problem
when I change the tested value inside the SELECT CASE command processing.
But only the first valid condition seems to be executed, even if another valid one follows.
A = 1
Select Case A
Case 1 : A = 3
Case 1 To 3 : A = 6
End Select
Print A
3
Thanks for the posts
PostPosted: Sat Feb 12, 2022 7:17 pm    Post subject: Reply with quote
I wrote
select case -----end select allows to go directly to the line corresponding to the requested value
It is better to write
to go directly to the line corresponding to the requested ONLY !
your code is absolutly bad
A = 1
Select Case A
Case 1 : A = 3
Case 1 To 3 : A = 6
End Select
You can't write
case 1 and case 1 to 3
but you can write
Case 1
case 2 to 3
A select case/ end select
is only as the help said
Select Case I
Case 1 : Print "1"
Case 2 : Print "2"
Case 3 To 5 : Print "3-5"
Case Is >= 10 : Print ">= 10"
Case Else : Print "Not in Case statement"
End Select
jp Wink
SZTRAD
PostPosted: Sat Feb 12, 2022 7:21 pm    Post subject: Reply with quote
It is the same for all languages.You look for the first match and execute the conditions behind it. There's no reason for it to work any other way.
RS
PostPosted: Sat Feb 12, 2022 11:15 pm    Post subject: Reply with quote
Excuse, but both is utter nonsense.
How would the µC magically know for select case it's the third line? There's no indexed jump table or such.
To check if there's a matching query, comparisons have to be done for each query line, but only till there is a match.
This is exactly the same in select case as in if/elsif.
After a match is found, the query block is left immediately, if no match occurs, it runs the whole block.
If select case vs. if/elseif is to compare, the first gives a cleaner code structure.
That's the true difference.
In the simulator you can check the run-time for different values of Itm.
The compiler assembles the code for both versions slightly different, that's 4 cycles difference - which is nothing at all.
For preset: Itm = 1 both versions take 91 cycles.
$Regfile="m328def.dat"
$Crystal=4000000
$hwstack=40
$swstack=16
$framesize=32
Dim Itm As Byte
Itm = 3
' takes 101 cycles
Select Case Itm
  Case 1: Print 1
  Case 2: Print 2
  Case 3: Print 3
  Case 4: Print 4
  Case Else: Print "Else"
End Select
' takes 105 cycles
If Itm = 1 Then
  Print 1
ElseIf Itm = 2 Then
  Print 2
ElseIf Itm = 3 Then
  Print 3
ElseIf Itm = 4 Then
  Print 4
Else
  Print "Else"
PostPosted: Sat Feb 12, 2022 11:43 pm    Post subject: Reply with quote
Really bad, you mean absolutely devilishly awfully irresponsibly schockingly bad? Very Happy
Didn't you notice that SZTRAD only wanted to demonstrate that within overlapping queries only the first match is executed?
A = 1
Select Case A
Case 1 : A = 3
Case 1 To 3 : A = 6
End Select
You can't write
Of course he can, the result will be:
A = 1 --> Case 1 --> A = 3
A = 2 --> Case 1 To 3 --> A = 6
A = 3 --> Case 1 To 3 --> A = 6
loggercz
PostPosted: Sun Feb 13, 2022 11:47 am    Post subject: Reply with quote
thanks to all, basically, I asked inaccurately if only the first match will really be compared and the others will skip it. So is it...
PostPosted: Sun Feb 13, 2022 12:06 pm    Post subject: Reply with quote
saint MWS Pray I like you, you are a god to me, every time I make a logical comment you give me my punishment I said bad I should have said wrong, My English is quite primitive I am sorry.
I give bascom classes in a fablab, where I try to give basic notions and logic and I think my students appreciate my approach
Yes indeed select case comes out when they meet the first game
but my logic tells me not to do fuzzy logic and for me
Case 1 : A = 3
Case 1 To 3 : A = 6 ' this line is not logic after the upper one
Translated with www.DeepL.com
SZTRAD
PostPosted: Sun Feb 13, 2022 4:13 pm    Post subject: Reply with quote
And since Bascom is based on qbasic if my memory serves me right, we have no choice but to look at what our elders taught us in school.
"Select Case executes specific code depending on the value of an expression. The expression is evaluated once, and compared against each Case, in order, until a matching expression is found. The code inside the matching Case branch is executed, and the program skips down to the end of the Select Case block. Case Else matches any case not already matched, so if there is a Case Else, at least one Case is guaranteed to be executed. If no Cases match, the whole Select Case block will be skipped."
Where I am now, I have limited access to the book database. I'm sorry it took a little while to get it to me so I could copy it exactly from the '89 original.
Very Happy
RS
PostPosted: Sun Feb 13, 2022 6:11 pm    Post subject: Reply with quote
Wrong, I did correct you. And as you aggravated with 'absolutely', you'd have to say 'absolutely wrong'.
The sample was done to test behavior of a query where expression-ranges overlap.
Result was that only the first match executes.
To be able to show this, the expressions had to be this way.
Which took you to stampede-mode.
hgrueneis
PostPosted: Sun Feb 13, 2022 7:46 pm    Post subject: Reply with quote
There is really no need for any blame or discussion, just take a look at the HELP.!!! This is overblown!
Regards
Hubert
PostPosted: Sun Feb 13, 2022 9:38 pm    Post subject: Reply with quote
hgrueneis wrote:
There is really no need for ... discussion, ...
Well, some of the discussed points were worth it for me.
Have I to ask you next time? Very Happy
