New ver. does not show error
jure_m
PostPosted: Thu Feb 03, 2022 11:24 am    Post subject: New ver. does not show error Reply with quote
I have this code. If compiled with Bascom2085 it does not compile and does not say if there are any warnings and the program does not work:
$regfile = "M8def.dat "
$hwstack = 25
$swstack = 25
$framesize = 25
$crystal = 8000000
$baud = 38400
Config Submode = New
Dim B As Byte
Dim I As Byte
Dim Bb As Byte
Dim Ar(20) As Byte
Dim Sar As String * 20                                      'strng array
Dim Dl As String * 20                                       'strng array
Sar = "TEST LIA"
     Bb = 1
     Call Teststr(bb , Sar(1))
    Dl(b) = Dl(b) + "add"
End Sub
If I compile it with Bascom 2082, it shows errors :
Error : 238 Line : 25 Variable is not dimensioned as an array [SAR(1)]
Error : 263 Line : 25 Array index out of range [1] , in File : I:\Arhiv_Jure\BascomAVR\Jure\Doma\Jure\TMP_Rudi.bas
Error : 124 Line : 25 LOOP expected , in File : I:\Arhiv_Jure\BascomAVR\Jure\Doma\Jure\TMP_Rudi.bas
Is there something wrong with the file or new version of Bascom?
Best regards
Jure
(BASCOM-AVR version : 2.0.8.5 )
PostPosted: Thu Feb 03, 2022 11:51 am    Post subject: Reply with quote
you declare this : Declare Sub Teststr(b As Byte , Dl() As String)
which means you will pass an array of strings.
but then you use this : Call Teststr(bb , Sar(1))
which ok, is a string but: you dimmed it like : Dim Sar As String * 20
which is a normal string.
so no that will not work. that an older version allowed that does not mean it is ok.
and the error actual point this out.
PostPosted: Thu Feb 03, 2022 1:46 pm    Post subject: Re: New ver. does not show error Reply with quote
I use 2085 and get 4 errors. Likely your error window is hidden, try to reset the IDE.
