matjazs
Posted: Tue Jan 04, 2022 12:05 pm Post subject: Problem UART reading data |
I use ATMEGA128DB28 microcontroller and test serial interface. TX on all three ports work OK.
But when I try to recieve data, there is a problem with config serialin statement.
This error appear:
Quote: | Error : 101 Line : 24 Can't find HW-register [VPORTB_INTFLAGS ] , in File : E:\$Elektro\Projekti_MS2022\AVR128DB28TST\AVR128DB28_TST_Uart.bas
Error : 101 Line : 24 Can't find HW-register [VPORTE_INTFLAGS ] , in File : E:\$Elektro\Projekti_MS2022\AVR128DB28TST\AVR128DB28_TST_Uart.bas
Error : 101 Line : 24 Can't find HW-register [VPORTG_INTFLAGS ] , in File : E:\$Elektro\Projekti_MS2022\AVR128DB28TST\AVR128DB28_TST_Uart.bas
Error : 101 Line : 24 Can't find HW-register [PORTB_INTFLAGS ] , in File : E:\$Elektro\Projekti_MS2022\AVR128DB28TST\AVR128DB28_TST_Uart.bas
Error : 101 Line : 24 Can't find HW-register [PORTE_INTFLAGS ] , in File : E:\$Elektro\Projekti_MS2022\AVR128DB28TST\AVR128DB28_TST_Uart.bas
Error : 101 Line : 24 Can't find HW-register [PORTG_INTFLAGS ] , in File : E:\$Elektro\Projekti_MS2022\AVR128DB28TST\AVR128DB28_TST_Uart.bas
Error : 101 Line : 24 Can't find HW-register [TCA1_INTFLAGS ] , in File : E:\$Elektro\Projekti_MS2022\AVR128DB28TST\AVR128DB28_TST_Uart.bas
Error : 101 Line : 24 Can't find HW-register [TCB3_INTFLAGS ] , in File : E:\$Elektro\Projekti_MS2022\AVR128DB28TST\AVR128DB28_TST_Uart.bas
Error : 101 Line : 24 Can't find HW-register [TCB4_INTFLAGS ] , in File : E:\$Elektro\Projekti_MS2022\AVR128DB28TST\AVR128DB28_TST_Uart.bas
I think, that something is missing.
This is test code:
Code: | $regfile = "AVRX128db28.dat"
$crystal = 24000000
$hwstack = 40
$swstack = 40
$framesize = 40
'The AVRX series have more oscillator options
Config Osc = Enabled , Frequency = 24mhz
'set the system clock and prescaler
Config Sysclock = Int_osc , Prescale = 1
'configure the USART
Config Com1 = 9600 , Mode = Asynchroneous , Parity = None , Databits = 8 , Stopbits = 1
Open "COM1:" For Binary As #1
Config Com2 = 9600 , Mode = Asynchroneous , Parity = None , Databits = 8 , Stopbits = 1
Open "COM2:" For Binary As #2
Config Com3 = 9600 , Mode = Asynchroneous , Parity = None , Databits = 8 , Stopbits = 1
Open "COM3:" For Binary As #3
Config Serialin1 = Buffered , Size = 100 'read buffer COM2 THERE is a problem !!!!!!
'dimension a variable
Dim B As Byte
Config Portd.7 = Output
If Ischarwaiting(#2) = 1 Then
'Gosub Read_data
Toggle Portd.7
Print #1, "COM1" ; Spc(3) ; B
Print #2, "COM2" ; Spc(3) ; B
Print #3, "COM3" ; Spc(3) ; B
Waitms 1000
Incr B
Loop |
(BASCOM-AVR version : 2.0.8.5 ) |
Posted: Tue Jan 04, 2022 1:20 pm Post subject: |
yes it is a bug you need to download the add on again. it has corrected dat files.
all files were based on the 64 pin version which has more resources. some registers were not remarked in the 28/32 pin dat files that cause this problem. _________________ Mark |
matjazs
Posted: Wed Jan 05, 2022 9:19 am Post subject: |
Than'k you. It works now. I have one question more:
Code: |
$crystal = 24000000
$hwstack = 40
$swstack = 40
$framesize = 40
It works in all cases:
Code: | If Ischarwaiting(#2) = 1 Then
Gosub Read_data
End If |
or
Code: | If Ischarwaiting(#1) = 1 Then
Gosub Read_data
End If |
or
Code: | If Ischarwaiting() = 1 Then
Gosub Read_data
End If |
or
Code: | If Ischarwaiting(#3) = 1 Then
Gosub Read_data
End If |
My UART is connected on COM2 - pins PC0 and PC1 (config serialin1= Buffered , Size = 100)
Is there need to use MUX, or #1, #2, #3 don't have same function like using f.e. ATMEGA328? |
Posted: Wed Jan 05, 2022 1:12 pm Post subject: |
i do not understand what you mean.
but in your code #1 refers to com1 .in the config you can use txpin= DEF_PA0 or ALT1_PA4 so default is pa0-pa1
#2 points to com2 and txpin can be used too : DEF_PC0 or ALT1_PC4. in case txpin is not used the default is used(pc0-pc1)
etc.
when you use () without # it means the default com port which is com1
so it should work the same as with m328.
if not show an example where it behaves different.
here is some test code i used for tests
Code: |
'name : megaX.bas
'copyright : (c) 1995-2021, MCS Electronics
'purpose : demonstrates mega4809
'micro : mega4809
'suited for demo : no
'commercial addon needed : yes
'$regfile = "mx4809.dat"
$regfile = "AVRX128db64.dat"
$crystal = 24000000
$hwstack = 40
$swstack = 40
$framesize = 40
Const Ctestcom = 1 'use a range from 1-4 to test the COM port
Const Ctestcombuf = 1 'set to 1 to test buffered input
Const Ctesttca = 0 'set to 1 to test TCA
Const Ctestadc = 0 'set to 1 to test the ADC converter
Const Ctesti2c = 1 'set to 1 to test the master I2C
Const Ctesti2cslave = 1 'set to 1 to test the slave function. this requires the i2c slave add on
'optional configure the mux
'Config Port_mux = Overwrite , Usart0 = Alt1_pa4pa7 , Usart1 = None , Usart2 = Alt1_pf4pf6
#if Ctestcom = 1
Config Com1 = 19200 , Mode = Asynchroneous , Parity = None , Databits = 8 , Stopbits = 1 , Txpin = Alt1_pa4
#if Ctestcombuf
Config Serialin0 = Buffered , Size = 100
#endif
#elseif Ctestcom = 2
Config Com2 = 19200 , Mode = Asynchroneous , Parity = None , Databits = 8 , Stopbits = 1
Open "COM2:" For Binary As #1
#if Ctestcombuf
#endif
#elseif Ctestcom = 3
Config Com3 = 19200 , Mode = Asynchroneous , Parity = None , Databits = 8 , Stopbits = 1
Open "COM3:" For Binary As #1
#if Ctestcombuf
Config Serialin2 = Buffered , Size = 100
#endif
#elseif Ctestcom = 4
Config Com4 = 19200 , Mode = Asynchroneous , Parity = None , Databits = 8 , Stopbits = 1
Open "COM4:" For Binary As #1
#if Ctestcombuf
Config Serialin3 = Buffered , Size = 100
#endif
#endif
'Config Port_mux = Dummy , Spi0 = Default_pa4pa7 , Usart0 = Default_pa0pa3 , Tca0 = Default_pa0pa5
'enable the RTC
Config Clock = Soft , Rtc = 32khz_32khz_intosc
'the RTC requires that global interrupts are enabled
#if Ctesttca
Config Porta.2 = Output 'wo2
Config Tca0 = Pwm_bot , Prescale = 1 , Compare2 = Enabled , Resolution = Normal , Run = On 'začenemo timer TCA0 v t.i. "dual slope PWM" načinu na pinu PB0 (WO0)
Tca0_per = 8000 'ta register določa periodo oz. frekvenco PWM; FREKVENCA PWM = 16000000/(prescale * TCA0_PER * 2) = 1000Hz; TCA0_PER = 16000000/(prescale * 1000Hz * 2) = 8000
Tca0_cmp2 = 8000
Tca0_cmp2 = Tca0_cmp2 + 10
Waitms 1
#endif
Dim S As String * 16
Dim B As Byte
Dim W As Word
#if Ctesti2cslave
Twi0_dualctrl = 1 'slave pins on separate pins
Config Twi0slave = &H30 , Btr = 2
#endif
#if Ctesti2c
Config Xpin = Porta.2 , Outpull = Pullup
Config Xpin = Porta.3 , Outpull = Pullup
Config Twi0 = 100000 'CONFIG TWI will ENABLE the TWI master interface
I2cinit
Dim Twi_start As Byte , J As Byte
Print #1 , "Scan start"
For J = 0 To 255
I2cstart 'send start
I2cwbyte J 'send address
If Err = 0 Then 'we got an ack
Print "Slave at : " ; J ; " hex : " ; Hex(j) ; " bin : " ; Bin(j)
If J.0 = 0 Then 'ONLY if R/W bit is not set we may write data !!!
I2cwbyte 100 'just write to values to the slave
I2cwbyte 101
Else 'read
I2crbyte B , Ack : Print #1 , "GOT : " ; B 'read 2 bytes
I2crbyte B , Nack : Print #1 , "GOT : " ; B
I2cstop 'free bus
Print "End Scan"
Waitms 2000 'some delay and then repeat
#endif
#if Ctestadc
'configure the internal reference to be 1v1 for both the ADC and the DAC
Config Vref = Dummy , Adc0 = 1v1
'configure the ADC0 to read the temp sensor
Config Adc0 = Single , Resolution = 10bit , Adc = Enabled , Reference = Internal , Prescaler = 32 , Sample_len = 1 , Sample_cap = Above_1v , Init_delay = 32 , Mux = Tempsense
Const _adc_kelvin = 1 'when reading int sensor
'when getadc() does not have parameters, it will use the current mux setting
'other options are : getadc(channel) and getadc(adc0 | adc1 , channel)
W = Getadc(&H1e) : Print #1 , "W:" ; W
Waitms 1000
#endif
S = Time$
Print #1 , "1:" ; Time$
B = Inkey(#1)
If B <> 0 Then
B = Waitkey(#1)
Print "KEY:" ; B
Print #1 , "BIN:"
Inputbin #1 , B
Printbin #1 , B
If Ischarwaiting(#1) <> 0 Then
Print #1 , "wait"
Input #1 , "inp1" , S
#if Ctesti2cslave
'the following labels are called from the library when master send stop or start
'notice that these label names are valid for TWIC.
'for TWID the name would be TWID_stop_rstart_received:
Twi_stop_rstart_received:
Print #1 , "Master sent stop or repeated start"
'master sent our slave address and will not send data
Twi_addressed_goread:
Print #1 , "We were addressed and master will send data"
Twi_addressed_gowrite:
Print #1 , "We were addressed and master will read data"
'this label is called when the master sends data and the slave has received the byte
'the variable TWIx holds the received value
'The x is the TWI interface letter
Twi_gotdata:
Print #1 , "received : " ; Twi0 ; " byte no : " ; Twi0_btw
'here you would do something with the received data
' Select Case Twic_btw
' Case 1 : Portb = Twi ' first byte
' Case 2: 'you can set another port here for example
' End Select
'this label is called when the master receives data and needs a byte
'the variable twix_btr is a byte variable that holds the index of the needed byte
'so when sending multiple bytes from an array, twix_btr can be used for the index
'again the variable name depends on the twi interface
Twi_master_needs_byte:
Print #1 , "Master needs byte : " ; Twi0_btr
Select Case Twi0_btr
Case 1: ' first byte
Twi0 = 66 'we assign a value but this could be any value you want
Case 2 ' send second byte
Twi0 = 67
End Select
'when the mast has all bytes received this label will be called
Twi_master_need_nomore_byte:
Print #1 , "Master does not need anymore bytes"
#endif
End |
about portmux : you can use it. but take care : i would not use it together with the TXPIN option. also, the TXPIN option is more clear about configuration for that usart. but that is my opinion. _________________ Mark |
