Posted: Mon Sep 06, 2004 2:52 pm Post subject: Atmega128 PortF problem or question
What do I ned to do to enable or set the Portf.4 5 6 and 7 I/O pins to toggle high and low?
I wrote up the below program and although pins 0 thru 3 toggle high and low, the 4 thru 7 pins don't. I am wondering what I did or didn't do.
I am using Bascom ver 1.11.7.4 at this time.
'Bascom program:
$regfile = "m128def.dat"
$crystal = 14745600
Posted: Mon Sep 06, 2004 6:38 pm Post subject: I found the answer
Oops my mistake, I had forgotten that I needed to turn off the fuse setting for enabling the Jtag programming mode. Once I did disable the fuse setting, then the other four PortF I/O pins started working OK.
Earl
