syndetic1
Posted: Sun Nov 28, 2021 1:31 am Post subject: XMEGA ADC Selecting Channels |
Hi guys,
I am having trouble understanding the MUX selection on the XMEGA.
Here is what I know. At the end is a question on how to measure the internal ground voltage.
Chip is ATXMEGA128A3U-AU
I have the ADCs configured for single ended operation.
1
Config Adca = Single , Convmode = Unsigned , Resolution = 12bit , Dma = Off , Reference = Int1v , Event_mode = None , Prescaler = 32 , Ch0_gain = 1 , Ch0_inp = Single_ended , Mux0 = &B0000000, Ch1_gain = 1 , Ch1_inp = INTERNAL , Mux1 = &B1_000 , Ch2_gain = 1 , Ch2_inp = Single_ended , Mux2 = &B10000000 , Ch3_gain = 1 , Ch3_inp = Single_ended , Mux3 = &B1100000
Config AdcB = Single , Convmode = Unsigned , Resolution = 12bit , Dma = Off , Reference = Int1v , Event_mode = None , Prescaler = 32 , Ch0_gain = 1 , Ch0_inp = Single_ended , Mux0 = &B0000000, Ch1_gain = 1 , Ch1_inp = INTERNAL , Mux1 = &B1_000 , Ch2_gain = 1 , Ch2_inp = Single_ended , Mux2 = &B10000000 , Ch3_gain = 1 , Ch3_inp = Single_ended , Mux3 = &B1100000
2 From
http://ww1.microchip.com/downloads/en/Appnotes/00002535A.pdf
"In devices with two ADCs, the inputs can only be connected to the corresponding port. Meaning that ADCA can be connected only to PORT A, and ADC B can be connected only to PORT B."
The XMEGA I am using has 2 ADCs
3 The GetADC command in BASCOM looks like this:
var = GETADC( ADC , channel ,MUX)
Where ADC is A or B
Channel is a virtual channel number 0, 1, 2, 3 - I am using channel 0.
MUX is as follows
4 MUX
MUX is an 8 bit register.
Bit 7 is always 0
Bits 6543 - 4 bits select the source to the positive side of the ADC
Bits 210 - 3 bits select the negative side. 000 selects Ground
So to read PortA.0 the BASCOM command is:
MyVar = GETADC(ADCA, 0 , &b00000000)
PortA.1 is GETADC(ADCA, 0 , &b00001000)
and to read PortB
PortB0 MyVar = GETADC(ADCB, 0 , &b01000000) ie channel 8
PortB1 MyVar = GETADC(ADCB, 0 , &b01001000) ie channel 9
5 The data sheet tells me that there are various internal voltage sources including ground.
QUESTION
How do I read the internal ground voltage?
What is the config statement I need and what is the info to put in the GETADC command
Thanks in advance
(BASCOM-AVR version : 2.0.8.4 ) |
Posted: Sun Nov 28, 2021 2:07 pm Post subject: Re: XMEGA ADC Selecting Channels |
syndetic1 wrote: | How do I read the internal ground voltage? |
Not at all. If ground would be different to 0 volt, it would be broken. |
JC
Joined: 15 Dec 2007 Posts: 585 Location: Cleveland, OH
Posted: Sun Nov 28, 2021 10:32 pm Post subject: |
Actually, I think it is very reasonable to read the Internal Ground Voltage.
This is the Ground against which the other inputs are measured, in single ended input mode.
The issues is that depending upon the PCB, there may be significant currents flowing through the ground trace / plane, causing it's voltage to be different from the voltage source (-), and different from the ground level inside the chip.
Remember that if you have the data sheet in front of you, you can always re-configure the ADC by setting the registers yourself.
JC |
Posted: Mon Nov 29, 2021 1:52 am Post subject: |
JC wrote: | Actually, I think it is very reasonable to read the Internal Ground Voltage. |
I say it's nonsense, as if you want to measure something, you need a reference to measure it against.
What one of the chip's 6 GND's will be your reference then?
Quote: | The issues is that depending upon the PCB, there may be significant currents flowing through the ground trace / plane, causing it's voltage to be different from the voltage source (-), and different from the ground level inside the chip. |
If your PCB design would lead to different levels on the various chip GND's, you better start a new life in some better suited profession.
Quote: | Remember that if you have the data sheet in front of you, you can always re-configure the ADC by setting the registers yourself. |
If you or the TO would have actually have had a look into the data sheet, you'd have noticed that there is no such option of muxing an ADC input to GND.
Without knowing the chips internal layout, one can at least assume that GND pin 60 belongs to AVCC pin 61, which would lead to the further assumption, that these pin 60 an 61 serve the ADC sampling block.
This again would tell, that even if there would be tiny voltage shifts between several GND's, reference GND pin 60 is the one for which the ADC-result is valid.
Thus it makes no sense to measure this GND. |
syndetic1
Posted: Mon Nov 29, 2021 11:21 am Post subject: Re: Others have ADC issues |
syndetic1 wrote: | This bloke has a very interesting blog |
I would lend him credibility if he would not only offer opinions, instead providing measured data as proof.
Me prefers to read first source AVR1300, instead of second source opinions.
From the blog:
Quote: | but my experiments seemed to favour |
A "seemed to favor" is indeed mighty rocket science. LOL
However, proof that the blog did not work for you is: The blogger wrote about a benefit tying the negative input pin in differential mode and no gain to GND, creating thus a single ended input.
You asked:
Quote: | How do I read the internal ground voltage? |
If you do not know by now, you still did not read the data sheet. |
