' _____ _
' / ____| | |
' | | ___ _ _ _ __ | |_ ___ _ __
' | | / _ \| | | | '_ \| __/ _ \ '__|
' | |___| (_) | |_| | | | | || __/ |
' \_____\___/ \__,_|_| |_|\__\___|_|
' GUI-O V0.11.16 2021-11 www.gui-o.com
' |ATMEGA328 Arduino nano |
' |Clock 16.000000 Hz |
' |GLCD SSD1306 |
' |gammda 2021-11-09 |
'-Hardware connection----------------------------------------------------------
'* Bluetooth Arduino Nano SSD1306 *
'* | HC06 | | Mega 328 | | | *
'* | | | | | I2C | *
'* | | TX PortC.1 | | '------|----' *
'* | | RX PortC.0 | | SCL-PortC.5 | *
'* | | SCL-PortC.4 *
'* Input | | *
'* o------------| | *
'* D3 PinD3 | | *
'$sim
$regfile = "m328pdef.dat"
$crystal = 16000000
$baud = 9600
$hwstack = 60
$swstack = 60
$framesize = 60
Config Serialin = Buffered , Size = 120
Open "comc.1:9600,8,n,1" For Output As #1 'software serial port Bluetooth
Open "comc.0:9600,8,n,1" For Input As #2
' ST1306 LCD I2c 128x64 test example
Config Scl = Portc.5 ' used i2c pins
Config Sda = Portc.4
Config Twi = 400000 ' i2c speed
I2cinit
$lib "i2c_twi.lbx" ' we do not use software emulated I2C but the TWI
$lib "glcdSSD1306-I2C_V2.lib" ' override the default lib with this special one
Dim _contrast As Byte ' Contrast value of OLED. [0-255]
'Const Ssd1306_rotate = 0 ' Display rotation. [connection cable is lower side = 0, upper side = 1] rotate display 180 degrees.
Config Graphlcd = Custom , Cols = 128 , Rows = 64 , Lcdname = "SSD1306"
Cls
'Gettoken LIB declaration (parsing text)----------------------------------------
Dim Sep As Byte
Dim Pozicija As Byte
$lib "GetToken.Lib"
$external Gettoken
Declare Function Gettoken(strinput As String , Byval Bseparator As Byte , Byval Bcount As Byte ) As String
'-Declaration port--------------------------------------------------------------
Config Pind.3 = Input
Set Portd.3
Inp_ Alias Pind.3
'-Logotip picture---------------------------------------------------------------
Cls
Setfont Font8x8
Showpic 0 , 0 , Logoms
Wait 4
'-Define external interrupt INT1------------------------------------------------
Config Int1 = Low Level 'Interruption on Falling
On Int1 Count Nosave
Disable Interrupts
'-Variables---------------------------------------------------------------------
Dim Ii As Dword
Dim Iis As Single
Dim Iist As String * 20
Dim Iisf As String * 20
Dim Bt_key As Byte
Dim Znak As String * 15
Dim Bdata As String * 60
Cls
'-Start definition-------------------------------------------------------------
Setfont Font5x12
Lcdat 1 , 1 , "COUNTER"
Gosub Init_gui ' GUI-O initialization
Iisf = Format(iist , "00000000") 'Counter Zero screen LCD
Setfont Digital14x24
Lcdat 3 , 1 , Iisf
Print#1 , "@lbd TXT:'" ; Iisf ; "'" 'Counter Zero smart phone definition
Enable Int1
'-Main Loop--------------------------------------------------------------------
Main:
Disable Interrupts
Gosub Read_data ' Read information from software seral port
End 'End application
'--Init GUI-o -----------------------------------------------------------------
'=Initialization objects on Smartphone=========================================
Init_gui:
Disable Int1
Print #1 , "@sls 500"
Print #1 , "@cls"
Print #1 , "@clh"
Print #1 , "@clo"
Print #1 , "@gse COD:0 TSC:39"
Print #1 , "@guis BGC:#696969 ASR:0.449671"
Print #1 , "|SORI UID:sori1 HID:sori ORI:2 SEN:0"
Print #1 , "|BSR UID:bsr2 X:50 Y:50 W:90 H:85 VIS:1 ROT:0 RAD:1.5 BGC:#d3d3d3 SBGC:#d3d3d3 FGC:#d3d3d3 SHE:1 BTH:0.5" 'background rectangle
Print #1 , "|BSR UID:bsr3 X:55 Y:40 W:60 H:40 VIS:1 ROT:0 RAD:2 BGC:#000000 SBGC:#000000 FGC:#000000 SHE:1 BTH:0.5" ' backgroun display
Print #1 , "|LB UID:lbd X:55 Y:40 ALP:0 SHE:1 ROT:0 FGC:#a22200 FSZ:20 FFA:'font2' TXT:'" ; Iisf ; "'" ' counter digital noumber
Print #1 , "|LB UID:lb0 X:15 Y:15 ALP:0 SHE:1 ROT:0 FGC:#000000 FSZ:10 FFA:'font7' TXT:'Counter'" ' name of device
Print #1 , "|LB UID:lbt1 X:9 Y:28 ALP:1 SHE:1 ROT:0 FGC:#0350a2 FSZ:7 FFA:'font0' TXT:'Power'" 'Text power
Print #1 , "|LB UID:lbt2 X:9 Y:40.5 ALP:1 SHE:1 ROT:0 FGC:#0350a2 FSZ:7 FFA:'font0' TXT:'Pulse'" 'text pulse
Print #1 , "|LB UID:lblog X:80 Y:88 ALP:1 SHE:1 ROT:0 URL:1 FGC:#0350a2 FSZ:4 FFA:'font0' TXT:'www.gui-o.com'" 'Text GUI-O home page
Print #1 , "|SI UID:si1 X:21 Y:28 W:2.5 VIS:1 ROT:0 BGC:#B0C4DE FGC:#711700 SHE:1 EN:1" ' LED Power
Print #1 , "|SI UID:si2 X:21 Y:40.5 W:2.5 VIS:1 ROT:0 BGC:#B0C4DE FGC:#711700 SHE:1 EN:0" 'LED Pulse
Print #1 , "|BT UID:bt5 X:80 Y:75 W:8 H:16 SHE:1 ROT:0 RAD:0.5 BGC:#711700 SBGC:#711700 FGC:#FFFFFF FSZ:4 BTH:0 TXT:'RESET' SVAL:'reset'" 'Button reset
Print #1 , "|BT UID:btqt X:13 Y:28 W:10 H:10 SHE:1 ROT:0 RAD:0.5 BGC:#00711700 SBGC:#00711700 FGC:#00FFFFFF FSZ:4 BTH:0 TXT:'Quit app' SVAL:'reset'" 'Button Quit- hidden on text "Counter"
Print #1 , "@hls 200"
Enable Int1
'Reading data from serial port - from GUI-O keys (UID names)
Read_data:
Bt_key = Inkey(#2)
If Bt_key = "@" Then Input #2 , Bdata Noecho
Sep = &H20
Pozicija = 1
Znak = Gettoken(bdata , Sep , Pozicija)
If Znak = "bt5" Then 'Key Reset counter
Ii = 0
Iis = Ii
Iist = Str(ii)
Lcdat 3 , 1 , Iisf
Znak = " "
If Znak = "btqt" Then
Print #1 , "@quitapp" 'Quit application
Znak = " "
If Znak = "init" Then 'Start key Initialization
Gosub Init_gui
Znak = ""
Znak = ""
Bdata = ""
Enable Int1
'-Procedure for interrupt INT1--------------------------------------------------
Count:
Disable Interrupts
Print #1 , "@si2 EN:1"
If Inp_ = 0 Then
Ii = Ii + 1
While Inp_ = 0
Wend
Iist = Str(ii)
Lcdat 3 , 1 , Iisf
Print #1 , "@si2 EN:0"
'-EEprom-----------------------------------------------------------------------
R_eep:
' Readeeprom Ii , &H10 'In case saving data to EEPROM
'-GLCD fonts / Logo picture----------------------------------------------------
$include "Digital14x24.font"
$include "font5x12.font"
$include "font8x8.font"
Logoms:
$bgf "Logoh2o.bgf"
