PWM: how to set prescale seperately?
ulfbc
PostPosted: Sun Oct 31, 2021 11:50 am    Post subject: PWM: how to set prescale seperately? Reply with quote
Hi all
I want use a 8bit PWM (Timer1) at a ATTiny 4313. Depending on user settings the parameters "Output" and "Prescale should be set.
my variables are
pwm_prescale_ee: set Prescale
pwm_kanal4_ee: activate PWM on Portb.4
pwm_kanal5_ee: activate PWM on Portb.3
at the moment I'm doing this:
if pwm_kanal4_ee >= 1 and pwm_kanal5_ee = 0 then  'PWM-Ausgänge aktivieren
 select case pwm_prescale_ee  '
   case 10 'A
      Config Timer1 = Pwm , Pwm = 8 , Compare B Pwm = Clear Up , Prescale = 1024      '1024 = 15Hz
   case 11 'B
      Config Timer1 = Pwm , Pwm = 8 , Compare B Pwm = Clear Up , Prescale = 256    '256 = 61Hz
   case 12 'C
      Config Timer1 = Pwm , Pwm = 8 , Compare B Pwm = Clear Up , Prescale = 64      '64 = 244Hz
   case 13 'D
      Config Timer1 = Pwm , Pwm = 8 , Compare B Pwm = Clear Up , Prescale = 8       '8 =  1953Hz
   case 14 'E
      Config Timer1 = Pwm , Pwm = 8 , Compare B Pwm = Clear Up , Prescale = 1       '1 = 15625Hz
 end select
end if
if pwm_kanal4_ee = 0 and pwm_kanal5_ee >= 1 then   'PWM-Ausgänge aktivieren
   case 10 'A
      Config Timer1 = Pwm , Pwm = 8 , Compare A Pwm = Clear Up , Prescale = 1024      '1024 = 15Hz
   case 11 'B
      Config Timer1 = Pwm , Pwm = 8 , Compare A Pwm = Clear Up , Prescale = 256    '256 = 61Hz
   case 12 'C
      Config Timer1 = Pwm , Pwm = 8 , Compare A Pwm = Clear Up , Prescale = 64      '64 = 244Hz
   case 13 'D
      Config Timer1 = Pwm , Pwm = 8 , Compare A Pwm = Clear Up , Prescale = 8       '8 =  1953Hz
   case 14 'E
      Config Timer1 = Pwm , Pwm = 8 , Compare A Pwm = Clear Up , Prescale = 1       '1 = 15625Hz
 end select
end if
if pwm_kanal4_ee >= 1 and pwm_kanal5_ee >= 1 then  'PWM-Ausgänge aktivieren
   case 10 'A
      Config Timer1 = Pwm , Pwm = 8 , Compare A Pwm = Clear Up , Compare B Pwm = Clear Up , Prescale = 1024      '1024 = 15Hz
   case 11 'B
      Config Timer1 = Pwm , Pwm = 8 , Compare A Pwm = Clear Up , Compare B Pwm = Clear Up , Prescale = 256    '256 = 61Hz
   case 12 'C
      Config Timer1 = Pwm , Pwm = 8 , Compare A Pwm = Clear Up , Compare B Pwm = Clear Up , Prescale = 64      '64 = 244Hz
   case 13 'D
      Config Timer1 = Pwm , Pwm = 8 , Compare A Pwm = Clear Up , Compare B Pwm = Clear Up , Prescale = 8       '8 =  1953Hz
   case 14 'E
      Config Timer1 = Pwm , Pwm = 8 , Compare A Pwm = Clear Up , Compare B Pwm = Clear Up , Prescale = 1       '1 = 15625Hz
 end select
end if
works well but wastes a lot of flash memory.
My question: how to set the Prescale independly of the hole timer config?
(BASCOM-AVR version : 2.0.8.2 , Latest : 2.0.8.4 )
Evert :-)
PostPosted: Sun Oct 31, 2021 11:53 pm    Post subject: Reply with quote
You can set the 3 bits for the prescaler manually in the TCCR1B register.
For example prescale 64;
tccr1b.cs10 =1
tccr1b.cs11 =1
tccr1b.cs12 =0
Have look at the datasheet page 114 for the possible values
ulfbc
PostPosted: Mon Nov 01, 2021 10:06 am    Post subject: Reply with quote
found it in the datasheet, but I had no idea to code it in Bascom
thanks a lot
PostPosted: Tue Nov 02, 2021 10:57 am    Post subject: Reply with quote
Try it. Should work.
Dim Pwm_kanal4_ee As Eram Byte
Dim Pwm_kanal5_ee As Eram Byte
Dim Pwm_prescale_ee As Eram Byte
Const P1 = &B000_001
Const P8 = &B000_010
Const P64 = &B000_011
Const P256 = &B000_100
Const P1024 = &B000_101
Tccr1a = &B0000_0001                                        'WGM10 for PWM, Phase Correct, 8-bit
If Pwm_kanal4_ee > 0 Then Set Tccr1a.com1a1
If Pwm_kanal5_ee > 0 Then Set Tccr1a.com1b1
 Select Case Pwm_prescale_ee
   Case 10
      Tccr1b = P1024
   case 11 'B
      Tccr1b = P256
   Case 12
      Tccr1b = P64
   case 13 'D
      Tccr1b = P8
   Case 14
      Tccr1b = P1
 End Select
ulfbc
PostPosted: Thu Nov 04, 2021 7:59 pm    Post subject: Reply with quote
works !
thanks for help
saved round about 15% of my flash Very Happy
