problem I2C AS5600
marcosx
PostPosted: Sat Oct 30, 2021 12:17 pm    Post subject: problem I2C AS5600 Reply with quote
HI to all.
I have a problem with I2C AS5600 is an easy to program magnetic rotary position
sensor with a high-resolution 12-bit.
$regfile = "m328pdef.dat"
$crystal = 16000000
Config Lcd = 16 * 2
Config Lcdpin = Pin , Db4 = Portd.4 , Db5 = Portd.5 , Db6 = Portd.6 , Db7 = Portd.7 , E = Portb.1 , Rs = Portb.0
Cls
Cursor Off
Config I2cdelay = 10
Config Scl = Portc.5
Config Sda = Portc.4
Dim Napiecie As Long                                        'Long
Dim Pomiarh As Byte , Pomiarl As Byte
Dim Wynik As Long
Cls
Lcd "Start"
Wait 1
Cls
      I2cstart
      I2cwbyte 108                                          '108    ' I2cwbyte &B01101100
      I2cstop
      I2cstop
      I2cstart
      I2cwbyte 109                                          ' 109   ' I2cwbyte &B01101101
      I2crbyte Pomiarh , Ack                                'Odczyt Pomiaru
      I2crbyte Pomiarl , Nack
      I2cstop                                               'Bit Stopu
      Waitms 1
      Napiecie = Makeint(pomiarl , Pomiarh)
      Wynik = Napiecie
      Locate 1 , 1
      Lcd Wynik ; "   "
   Wait 1
Compiler version :2.0.8.2
Compiler build :2.0.8.2.003
(BASCOM-AVR version : 2.0.8.4 , Latest : 2.0.8.4 )
_jarek_
PostPosted: Sat Oct 30, 2021 8:19 pm    Post subject: Reply with quote
You are reading "Configuration Registers"
Output registers are in 0C-0F adress.
Pikczu
PostPosted: Sun Nov 07, 2021 2:05 pm    Post subject: Reply with quote
If you are interested I have shared the code for 14 bit AS5047D on EDC forum https://bart-projects-forum.cba.pl/viewtopic.php?f=13&t=363
But it is SPI, not I2C.
