problem with 40x4 LCD
Goto page Previous  1, 2
PostPosted: Thu Oct 28, 2021 11:34 am    Post subject: Reply with quote
I dont'have 40 X 4 display so I write a very simple program
I tested this simple program, I understand that the compiler translates Config Lcd 40 * 4 as
"I must use the 40x4 library".
or Config Lcd 20 * 4 as
"I must use the 20x4 library".
the test result seems to show a bug in the compiler/simulator
'test40X4
$regfile = "m1284pdef.dat"
$crystal = 11052000
$hwstack = 375
$swstack = 200
$framesize = 200
Config Submode = New
$sim
'---lcd --------------------------------------------------------------------
Config Lcdpin = Pin , Db4 = Porta.2 , Db5 = Porta.3 , Db6 = Porta.4 , Db7 = Porta.5 , E = Porta.1 , Rs = Porta.0
'Config Lcd = 40 * 4
Config Lcd = 20 * 4
' test lcd
'Locate 1 , 1 : Lcd "123456789A123456789A123456789A123456789A"
'Locate 2 , 1 : Lcd "123456789B123456789B123456789B123456789B"
'Locate 3 , 1 : Lcd "123456789C123456789C123456789C123456789C"
'Locate 4 , 1 : Lcd "123456789D123456789D123456789D123456789D"
' test lcd
Locate 1 , 1 : Lcd "123456789A123456789A"
Locate 2 , 1 : Lcd "123456789B123456789B"
Locate 3 , 1 : Lcd "123456789C123456789C"
Locate 4 , 1 : Lcd "123456789D123456789D"
Thirdline
 Fourthline
PostPosted: Thu Oct 28, 2021 11:49 am    Post subject: Reply with quote
the fact that the CONFIG does not support a second Enable should be sufficient to understand that 2 enable lines are not supported.
Page 2 of 2
