EEProm problem
svberg
PostPosted: Thu Oct 21, 2021 9:35 am    Post subject: EEProm problem Reply with quote
Hi.
Have a strange problem. Need to set some default values in EEprom, but one byte is failing.
I'm doing this;
zb=0
xi=50
Writeeeprom zb,xi '"0" Key OFF
incr xi
zb=1
Writeeeprom zb,xi '"1" Key On Board
incr xi
Writeeeprom zb,xi '"1" Key On Route
incr xi
zb=0
Writeeeprom zb,xi '"0" Key On Shore
incr xi
zb=20
Writeeeprom zb,xi '"20" Current limit at 20A
incr xi
zb=1
Writeeeprom zb,xi '"1" Limit type Normal
incr xi
zb=1
Writeeeprom zb,xi '"1" Lock down
I then read back the content of the EEprom, both with the programmer, and in my program, everything is fine, except the line Limit Type Normal.. There I read the hex byte 31 which is 49 des. and asc 1.
WHY, WHY???
Anybody encountered something like this??
Using Bascom 2.0.8.4 with ATMEGA2560. Programming with Arduino STK500V2.
(BASCOM-AVR version : 2.0.8.4 )
PostPosted: Thu Oct 21, 2021 10:25 am    Post subject: Reply with quote
TYPE is a reserved word.
you better not use it.
instead of Writeeeprom you can best use the pseudo variable ERAM. Much simpler. See help : DIM var as ERAM byte
if you can not solve the problem you should show a small sample that we can actual test, thus including $regfile, etc.
Paulvk
PostPosted: Fri Oct 22, 2021 1:51 am    Post subject: Reply with quote
I use a Eram Array for such variables.
This makes it easy to read the default as it is a variable.
If you are use to Arduino code you have to read more of Bascom's help
because Bascom does a lot of the work for you it has very powerful functions
that Arduino does not , two of note are the Split function and the Overlay
I have been programming ESP8266 with Arduino and with what I can
do with one command in Bascom takes a dozen lines of code with Arduino
RegardsPaul
 Dim Defaults(10) As Eram Byte
 Dim A As Byte
 Dim B As Byte
 A = 0                                                      'Key OFF
 Defaults(1) = A
 A = 1                                                      'Key On Board
 Defaults(2) = A
 A = 1                                                      'Key On Route
 Defaults(3) = A
 A = 0                                                      'Key On Shore
 Defaults(4) = A
 A = 20                                                     'Current Limit at 20A
 Defaults(5) = A
 A = 1                                                      'Limit type Normal
 Defaults(6) = A
 A = 1                                                      'Lock down
 Defaults(7) = A
  'Now to find the current limit
  B = Defaults(5)
  ' variable B now will have the value of 20
