W5500 Tcpwrite hang
Post new topic   Reply to topic    www.mcselec.com Forum Index -> EASY TCP/IP
amir.eshraghi@aii1.com
PostPosted: Fri Dec 03, 2021 1:50 am    Post subject: W5500 Tcpwrite hang Reply with quote
Hi
When I run sample code of W5200 client it work find but when I run with my code(exact same code) which use interrupts, and many other stuff it hangs at
[Result = Tcpwrite(idx , "Hello from W5200A{013}{010}")  ]
or it send junk,.
for example:
Result = Tcpwrite(idx , "r")
or it hangs , or send you junk variable.
I have no clue what is causing this . Does easy Tcpwrite using specific timer or interrupt that I am using too. (I only use external interrupt every one second).
Please let me know if you have any questions.
'name                     : dhcp_W5500.bas
'copyright                : (c) 1995-2017, MCS Electronics. Based on dhcp.bas from Atilio Mosca
'purpose                  : demo: DHCP
'micro                    : Mega88
'suited for demo          : no
'commercial addon needed  : only hardware
$regfile = "M2560def.dat"                                   'ATMEGA2560 (TQFP)
$crystal = 7372800                                          'oscillator speed (MHz)
Config Clockdiv = 1                                         'clock divider
Config Clock = User                                         'use compiler time functions w/ user set time & date
$loadersize = 4096
$hwstack = 200                                              'hardware stack size (30)
$swstack = 200                                              'software stack size (51)
$framesize = 2000                                           'frame size (1419)
'$lib "stackcheck.lib"
     $baud = 19200                                               ' use baud rate
$hwstack = 128                                              ' default use 32 for the hardware stack
$swstack = 128                                              ' default use 10 for the SW stack
$framesize = 128                                            ' default use 40 for the frame space
Declare Function Xidcookie_ok() As Byte
Declare Function Parse_dhcp_msg(byval Doption As Byte) As Byte
Declare Function Dhcp_ok() As Byte
Declare Sub Print_parse()
Dim Mac_add(6) As Byte
                       ' result
Tcp_cs Alias Porth.3 : Set Tcp_cs                           'Ethernet chip select
status Alias portd.6 : Set status
  reset status
'This number should match the one in the 'Config Tcpip...' line
'Do not use first byte
Mac_add(1) = 0
Mac_add(2) = 128
Mac_add(3) = 12
Mac_add(4) = 34
Mac_add(5) = 56
Mac_add(6) = 78
  Config Spi = Hard , Interrupt = Off , Data Order = Msb , Master = Yes , Polarity = High , Phase = 1 , Clockrate = 4 , Noss = 0
  Spsr = 1
  Spiinit
'Print "Init , set IP to 192.168.1.70"                       ' display a message
Config Tcpip = Noint , Mac = Mac_add(1) , Ip = 10.0.16.56 , Submask = 255.255.255.0 , Gateway = 10.0.16.254 , Localport = 1000 , Chip = W5500 , Spi = 1 , Cs = Tcp_cs
   Dim Bclient As Byte                                         ' socket number
Dim Idx As Byte
Dim Result As Word , Result2 As Word    , Result3 As Word                    ' result
Dim S As String * 80
Dim Flags As Byte
Dim Peer As Long
Dim L As Long
  Waitms 1000
  For Idx = 0 To 3
     Result = Socketstat(idx , 0)                           ' get status
     Select Case Result
       Case Sock_established
            If Flags.idx = 0 Then                           ' if we did not send a welcome message yet
               Flags.idx = 1
               Result = Tcpwrite(idx , "Hello from W5200A{013}{010}")       ' send welcome
            Result = Socketstat(idx , Sel_recv)             ' get number of bytes waiting
            If Result > 0 Then
            Result3 = Tcpwrite(idx , "Hello")
                  Result3 = Tcpwrite(idx , "here")
                  set status
                 Result = Tcpread(idx , S)
                 reset status
                  Result3 = Tcpwrite(idx , "Pass")
                 If Lcase(s) = "exit" Then
                    Result2 = Tcpwrite(idx , "exit" )
                 Elseif Lcase(s) = "time" Then
                    Result2 = Tcpwrite(idx , "12:00:00{013}{010}")       ' you should send date$ or time$
               Loop Until Result = 0
       Case Sock_close_wait
            Closesocket Idx
       Case Sock_closed
            Bclient = Getsocket(idx , Sock_stream , 5000 , 0)       ' get socket for server mode, specify port 5000
            Socketlisten Idx
           ' Print "Result " ; Result
            Flags.idx = 0                                   ' reset the hello message flag
     End Select
  Next   Idx
End]
[/code]
PostPosted: Sat Dec 04, 2021 11:32 am    Post subject: Reply with quote
you best clean up the sample it has multiple $hwstack for example.
from the help ; W5500 only supports the NOINT option.
Post new topic   Reply to topic    www.mcselec.com Forum Index -> EASY TCP/IP All times are GMT + 1 Hour
