ATXMega 32 E5 - XCL Event System Counter/Timer Overflow/Unde
andrge
PostPosted: Wed Aug 18, 2021 1:15 pm    Post subject: ATXMega 32 E5 - XCL Event System Counter/Timer Overflow/Unde Reply with quote
Hello,
i have a little issue on getting my over/underflow handler working.
The goal of this project is to count the numbers of falling edges on the pin C4 and C5 on a somewhat close hardware-level using XCL.
From what i've found on research is that there are not that many examples out there for that topic especially not for the MCU i am using.
I've started on a small example from MCS for the xm128a1 with the relevant lines being
Config Event_system = Dummy , Mux0 = Porte.5 , Digflt0 = 8 'Eventchannel 0 = PINE.5, enable digital filtering Config Tcc0 = Normal , prescale = E0 , Event_source = E0 , Event_action = capture
On Tcc0_ovf Timerd0_int
Enable Tcc0_ovf , lo 'Enable overflow interrupt in LOW Priority
Tcc0_per = 5 'Interrupt when Count > 5
Timerd0_int:
which turned out to this
$regfile = "xm32E5def.dat"
$crystal = 32000000
$hwstack = 65
$swstack = 65
$framesize = 65
'baud 19200
$programmer = 16        'USBprog Programmer/ AVR ISP mkII (Atmel)
... clock correction ...
'UARTD0, PIN 32, 33
Open "com1:" For Binary As #1
'Open UARTS
'Startausgabe
Print #1 , "-------------------------------------"
Print #1 , "              Welcome"
'Variablen
Dim CounterSecondByte as Byte
Dim CounterTotal As Word
Config PortC.4 = Input
Config Xpin = PortC.4 , Outpull = Pullup , Sense = Falling                                          'enable Pullup and reaction on falling edge
Config Event_system = Dummy , Mux0 = PortC.4 , Digflt0 = 8                                          'Eventchannel 0 =  PINE.5, enable digital filtering
Config Tcc4 = Normal , Prescale = E0 , Event_source = E0 , EVENT_ACTION = RESTART , RESOLUTION = Byte       ' Normal = no waveform generation, Event Source = Event Channel 0
' set the direction to count up
TCC4_CTRLGSET.0 = 0
On Tcc4_ovf Timerc4_int
Enable Tcc4_ovf , Lo
' Interrupt @ 256 -> 0xFF
Tcc4_per = 255
'################MAINLOOP#######################################################
    ' Interval
    Waitms 500
    ' CounterTotal = (CounterSecondByte << 8) | TCC4_CNT
    CounterTotal = CounterSecondByte
    Shift CounterTotal , Left , 8
    CounterTotal = CounterTotal Or TCC4_CNT
    ' Debug Ausgabe
    Print #1 , "TCC4_CNT = " ; CounterSecondByte ; " | " ; TCC4_CNT ; " = " ; CounterTotal ; " EXT " ; High(TCC4_CNT)
Timerc4_int:
    ' increment high
    Incr CounterSecondByte
However i am experiencing a strange issue. Once the over/underflow happened and the handler is being called it won't stop to interrupt and blocks the main loop.
TCC4_CTRLA 00001000
TCC4_CTRLB 01000000
TCC4_CTRLC 00000000
TCC4_CTRLD 10101000
TCC4_CTRLE 00000000
TCC4_CTRLF 00000000
INTCTRL 00000000 | 00000000
TCC4_CTRLGCLR 00000000
TCC4_CTRLGSET 00000000
TCC4_CTRLHCLR 00000000
TCC4_CTRLHSET 00000000
TCC4_INTFLAGS 00000000
TCC4_TEMP 00000000
I have tried to switch some promising bits in various registers attached to the timer but they weren't noticabely improving the situation.
(BASCOM-AVR version : 2.0.8.3 , Latest : 2.0.8.4 )
PostPosted: Wed Aug 18, 2021 8:05 pm    Post subject: Re: ATXMega 32 E5 - XCL Event System Counter/Timer Overflow/ Reply with quote
The XMegas do not clear interrupt flags by executing the interrupt vector, instead they want flags cleared by user code, i.e in this case writing a 1 into INTFLAGS.OVFIF.
https://www.microchip.com/content/dam/mchp/documents/OTH/ProductDocuments/DataSheets/Atmel-42005-8-and-16-bit-AVR-Microcontrollers-XMEGA-E_Manual.pdf
Page 180.
andrge
PostPosted: Thu Aug 19, 2021 3:49 pm    Post subject: Reply with quote
I thought i tried setting that bit already but it seems to work now. Thank you.
