Differences where variable dimensioned?
This forum is locked: you cannot post, reply to, or edit topics.   This topic is locked: you cannot edit posts or make replies.    www.mcselec.com Forum Index -> BASCOM-AVR Unsupported versions
KenHorse
PostPosted: Sat Aug 07, 2021 6:25 pm    Post subject: Differences where variable dimensioned? Reply with quote
Is there any practical difference between declaring a variable this way:
Sub Whatever
Dim Array(10) as Byte
    <code of sub>
End Sub
versus this:
Sub Whatever
   <code of sub>
End Sub
[/code]
(BASCOM-AVR version : 2.0.8.3 , Latest : 2.0.8.4 )
Evert :-)
PostPosted: Sat Aug 07, 2021 7:31 pm    Post subject: Reply with quote
Form the help file:
SCOPE
The scope for DIM is global. So no matter where you use the DIM statements, the variable will end up as a global visible variable that is visible in all modules, procedures and functions.
When you need a LOCAL variable that is local to the procedure or function, you can use LOCAL.
Since LOCAL variables are stored on the frame, it takes more code to dynamic generate and clean up these variables. This because all functions and subs are fully re-entrant. (re-entrant means they can call themselves recursively)
So, no there's no difference.
Except that in the second case it's clear that the variable belongs(needed by) to the sub.
KenHorse
PostPosted: Sat Aug 07, 2021 8:09 pm    Post subject: Reply with quote
And where those variables are actually stores within RAM, yes?
This forum is locked: you cannot post, reply to, or edit topics.   This topic is locked: you cannot edit posts or make replies.    www.mcselec.com Forum Index -> BASCOM-AVR Unsupported versions All times are GMT + 1 Hour
