which microSD ??
Post new topic   Reply to topic    www.mcselec.com Forum Index -> AVR-DOS
Sarek
PostPosted: Thu Aug 19, 2021 1:15 pm    Post subject: which microSD ?? Reply with quote
Hello,
I use a microSDHC for data logging on a XMega.
Now we have severe problems with the SD-Cards, we use Intenso 4GB Class 4 microSDHC.
About 50% of about 100 Cards are running, but the other 50% do not...
I called Intenso support, and they told me that SPI Interface is not in their specification, because this is a consumer product.
Has someone an idea which microSD we can use? They should be 100% SPI compatible!
Thanks
plouf
PostPosted: Thu Aug 19, 2021 2:30 pm    Post subject: Reply with quote
you just reached "first level support" who can tell up to how to format it
try with kingstone
reason is that they have the specification ON THEIR SITE -> http://www.kingston.com/datasheets/SDCIT-specsheet-64gb_en.pdf
which clearly states that card support both SD and SPI interface
at any case you can reach somehow someone,in case of problem, (someone must put this pdf online)
Sarek
PostPosted: Thu Aug 19, 2021 2:42 pm    Post subject: Reply with quote
Thanks plouf
but this datasheet is for SDXC Cards, which are not supported by AVR-DOS.
Do you have any experience with Kingston Cards and AVR-DOS?
plouf
PostPosted: Thu Aug 19, 2021 2:54 pm    Post subject: Reply with quote
no i have no personal experience
hoewever this is for kingstone and sdhc
www.kingston.com/datasheets/SDCIT-specsheet-8gb-32gb_en.pdf
they clearly state it..
and at least seems that in Kingstone they KNOW what spi is , and what their cards support !!
PostPosted: Thu Aug 19, 2021 4:15 pm    Post subject: Reply with quote
did you format the sd card before use it ?
see https://www.sdcard.org/downloads/formatter/
I use a lot of Micro SD card mainly sandisk 8Gb SDHC I never have pb
JP
Wink
Sarek
PostPosted: Thu Aug 19, 2021 4:25 pm    Post subject: Reply with quote
Yes I tried to format it with SDCARD org Formatter
I order now 10pieces of Kingston microSDHC 8GB
this is Industrial version
I will test and report here
Sarek
PostPosted: Thu Aug 19, 2021 4:34 pm    Post subject: Reply with quote
@Duval JP
It seems that the small Sandisk (4/8GB) microSDHC are End of Life. => poorly available
Post new topic   Reply to topic    www.mcselec.com Forum Index -> AVR-DOS All times are GMT + 1 Hour
