DDS AD9833 Controller for Arduino LCD Keypad Shield.
O-Family
PostPosted: Mon Feb 10, 2020 2:20 am    Post subject: DDS AD9833 Controller for Arduino LCD Keypad Shield. Reply with quote
Analog Devices AD9833 is controlled by Arduino LCD Keypad Shield.
The connection to the DDS module is made up of two power lines and three SPI interfaces.
Circuit diagram
https://drive.google.com/open?id=1JXYliu83b2AujtUyNUQxdRVs0yE652_f
Operate using the character LCD and key switch mounted on the “LCD Keypad Shield” board.
Move the setting cursor displayed at the bottom of the LCD to set the output waveform and frequency.
The operation method of the key switch is described in the following "Operation Manual".
https://drive.google.com/open?id=1esjkVThUk-4vaVL1UG9J_TNtK0uRFcV8
PostPosted: Mon Feb 10, 2020 10:47 am    Post subject: Reply with quote
Hello O-Family
Thank you for sharing your project.
The circuit and instruction pdfs are very clear. While your code is easy to read, i thank you for taking the time to make the operating manual. There are many options and this is very convenient Very Happy
O-Family
PostPosted: Thu Feb 13, 2020 1:35 am    Post subject: AD9833 with MCP41010 and OP amp(x6). Reply with quote
Thank you Mark!
continue,
This module is equipped with MCP41010 (digital potentiometer) and Operational Amplifiers (x6) in AD9833.
Sine and triangle waves have an amplitude of up to about 3.6V, and the amplitude can be changed on the LCD screen using a digital potentiometer.
This is a practical and easy-to-use module!
Circuit diagram
https://drive.google.com/open?id=1vE4XgChqopJBAQJ6fuklBH0un3O9V0ni
Operation Manual
https://drive.google.com/open?id=17VBoasE-uPQCRK9od9ER5dWbhVoKE6cc
PostPosted: Fri Feb 14, 2020 3:28 pm    Post subject: Reply with quote
an excellent addition.
Do you have a link for the second board? Where to purchase i mean.
Plons
PostPosted: Fri Feb 14, 2020 9:06 pm    Post subject: Reply with quote
https://www.banggood.com/AD9833-DDS-Signal-Generator-Module-0-12_5MHz-Square-Triangle-Sine-Wave-p-1161804.html?rmmds=search&cur_warehouse=CN
A general search for AD9833 on Banggood shows even more variations
Cheers
Nard
Bascom AVR ver 2.0.8.1
ProtectedParallelPortProgrammingDongle: http://www.aplomb.nl/TechStuff/PPPD/PPPD%20English.html
Dragon-lair: http://www.aplomb.nl/TechStuff/Dragon/Dragon.html
"leef met vlag en wimpel, maar hou het simpel"
O-Family
PostPosted: Sat Feb 15, 2020 12:38 am    Post subject: Reply with quote
I purchased from China by mail order.
https://ja.aliexpress.com/wholesale?catId=0&initiative_id=SB_20200214153813&SearchText=ad9833
And now, [AD9834], [AD9850], [AD9851] programs are also under construction.
O-Family
PostPosted: Wed Feb 19, 2020 2:32 am    Post subject: DDS AD9834 Controller for Arduino LCD Keypad Shield. Reply with quote
further,
The AD9834 has the ability to switch between two frequencies or phases with an external signal, and the test circuit uses the [FSELECT] pin to switch between the two frequencies, so FSK "Frequency Shift Keying" It is possible.
Circuit diagram
https://drive.google.com/open?id=1qqJxO--GohPUsI5i5yDWTJ-DRbDRi-m8
Operation Manual
https://drive.google.com/open?id=1_Kn6PKLaMgdcVujRCbDAC6-DdquenWs6
matjazs
PostPosted: Thu Apr 29, 2021 4:00 pm    Post subject: Reply with quote
Hello.
O-Family, I upgraded your project AD9833 that works paralell with your and GUI-O application on Smart phone.
All details (*.BAS code, Schematic, Pictures) are in attach.
https://www.youtube.com/watch?v=8iPABwZyiAc
www.gui-o.com
Regards, MS
O-Family
PostPosted: Fri Apr 30, 2021 12:36 am    Post subject: Reply with quote
Hi, matjazs
Great project!
I am also very interested in controlling from a smartphone.
It was a very good reference.
matjazs
PostPosted: Fri Apr 30, 2021 10:30 pm    Post subject: Reply with quote
Yes, it is very easy to program.
GUI-O is a universal application and there is no need to do anything on the Android device site.
You just select an object, give it a unique name, assign it an X and Y position on the screen and that's it.
In the opposite direction, you read the unique name and value that follows it.
f.e. @ bt1 1 (button named bt1 that sends the value 1)
The delimiter between the parameters can be a space or a comma.
