Problem with Single variable
Goto page 1, 2  Next
P_Santos
PostPosted: Wed Apr 21, 2021 10:12 pm    Post subject: Problem with Single variable Reply with quote
Below a piece of code to show the problem i have if i use single variables,
if i use instead, double variables it works correct
Anyone know what i make wrong??
Thank for any help
Regards
P_Santos
$hwstack = 70
$swstack = 70
$framesize = 70
$regfile = "m88def.DAT"
'# RC Osc Intern 8MHZ
$crystal = 8000000
Config Single = Scientific , Digits = 5                     'to show the Problem dif2 = 0.699995
'Config Single = Scientific , Digits = 3                     'print correct dif2 = 0.700 but not work on the If statment!
Dim Xc_ As Double , Saved_x As Double , Dif2 As Double , Irthreshold As Double
'Dim Xc_ As Single , Saved_x As Single , Dif2 As Single , Irthreshold As Single
Again:
    Xc_ = 840
    Dif2 = 0.70000
    Irthreshold = 0.70000
    Saved_x = Xc_ - Irthreshold
    Print "Saved_x " ; Saved_x ; " dif2x " ; Dif2
    Dif2 = Xc_ - Saved_x                                    'Problem with Single variable!!!!
    Print "DIF2 " ; Dif2 ; " xc_ " ; Xc_ ; " Saved_x " ; Saved_x
    Print "xc_ " ; Xc_ ; " dIF2 " ; Dif2 ; " TH " ; Irthreshold ; " Saved_x " ; Saved_x
    If Dif2 >= Irthreshold Then
       Print "OK Go " ; Dif2
    Else
       Print "Again " ; Dif2
       Goto Again
(BASCOM-AVR version : 2.0.8.3 , Latest : 2.0.8.3 )
laborratte
PostPosted: Thu Apr 22, 2021 9:34 am    Post subject: Reply with quote
Doing math with floating point values is always "non-precise". The obvious example in the decimal world is: 3 * (1/3) = 0.9999999999. As computers work binary rounding errors may occur on places where decimals are precise. That is why 840-0.7 = 839.0000005 or so.
If you use config single or config double only the print or str() statements are rounding to the given decimals - the value is not changed.
It is a good practice when comparing calculated floating point values to allow an error margin. So instead
if floatvar_A = floatvar_B then
end if
use something like
if abs(floatvar_A - floatvar_B) < 0.0005 then
end if
(this is not BASCOM syntax - just to show the idea...)
PostPosted: Thu Apr 22, 2021 9:38 am    Post subject: Reply with quote
your problems seems that you did not read the help. maybe because it is in English. But some good translators exist. also this forum has a search function, you could try it. although i admit in many cases it will give a lot of posts.
anyway it is explained in the help. if there are questions about the help just ask here.
Also you post some code which is very good. but you do not write what is wrong in your opinion.
Just read the LANGUAGE FUNDAMENTALS in the help (you get there when you look for SINGLE) and it should become clear why the SINGLE works as it does.
PostPosted: Thu Apr 22, 2021 9:43 am    Post subject: Reply with quote
and i like to add that you can scale an integer :
Dim XC ,dif2 as ling
Xc_ = 8400
Dif2 = 7
here i multiplied with a factor of 10. but it could be 100 or 1000 too.
then use format() to get the representation you like.
PostPosted: Thu Apr 22, 2021 10:00 am    Post subject: Re: Problem with Single variable Reply with quote
Your error is, that your question is not sharp enough, you do not tell what you expect.
Single is a variable with huge range but limited accuracy, and as bigger its value grows, as more accuracy of the decimal places gets lost.
Ideally your code would behave like that:
840 - 0.7 = 839.3
840 - 839.3 = 0.7
0.7 >= 0.7 ? = TRUE
Actually if you assign 840.0 to a single, already at the very point of assignment it may not represented internally with this exact value.
The same with 0.7, which leads to the subtraction result of 0.700000000000045, while 0.7 would be expected.
Your final if/else test is moot however, as 0.700000000000045 >= 0.7 branches the same as 0.7 >= 0.7
Also from your question it comes not clear, whether or not you misunderstand this config:
which is nothing else than eye-candy, respective print-candy, it alters only the representation against the "outer world", or in case of a conversion.
It does not affect internal representation of the value or calculations therewith.
I did not test Doubles, it may work different for them as Double-values sport twice the amount of bits for mantissa and exponent, also the Double-routines may apply some rounding,
Comparing any floats (Single/Double) is difficult, if you can not avoid it, you need to apply some rounding or truncation.
SZTRAD
PostPosted: Thu Apr 22, 2021 12:09 pm    Post subject: Reply with quote
Hi
you can understand what the guys are trying to tell you by adjusting your program a bit according to what Mark sent you.
Run the simulator and look at the results on the console. Interpreting what's after the decimal point is always problematic, but it's logical.
 $hwstack = 70
$swstack = 70
$framesize = 70
$crystal = 8000000
'Dim Xc_ As Double , Saved_x As Double , Dif2 As Double , Irthreshold As Double
 Dim Xc_z As Single , Saved_xz As Single , Dif2z As Single , Irthresholdz As Single
Again:
    Xc_ = 840
    Dif2 = 0.70000
    xc_z=xc_*10000
    Saved_xz=Saved_x*10000
    Dif2z=Dif2*10000
    Irthresholdz=Irthreshold*10000
    Print "xc_z " ; Xc_z ; " dIF2z " ; Dif2z ; " THz " ; Irthresholdz ; " Saved_xz " ; Saved_xz
    Dif2z = Xc_z - Saved_xz                                   'Problem with Single variable!!!!
    Print "DIF2 " ; Dif2 ; " xc_ " ; Xc_; " Saved_x " ; Saved_x
    Print "DIF2z " ; Dif2z ; " xc_z " ; Xc_z; " Saved_xz " ; Saved_xz
    Else
       Goto Again
RS
PostPosted: Thu Apr 22, 2021 3:30 pm    Post subject: Reply with quote
I was not trying to tell, as the phrase 'trying to' stands somehow for a rather failing approach.
I actually did tell.
xc_z=xc_*10000
Maybe a proverb fits here: Everything was already said, but not by everyone Very Happy
PostPosted: Thu Apr 22, 2021 3:43 pm    Post subject: Reply with quote
please do not make this a word game.
PostPosted: Thu Apr 22, 2021 4:18 pm    Post subject: Reply with quote
Had not the slightest intention to play word games.
I do not like that somebody degrades other posters messages for the purpose of creating a springboard for his own message.
My message was also not the kind needing explanation, interpretation or translation.
I made a two second break before start writing my previous post, these two seconds because English is not sztrad's native language and he may not understand that his words are degrading other members efforts.
Beginning the third second I thought, that he will be able to stand my cottony style post.
If not - I will call him Mimosa pudica in the future Very Happy
SZTRAD
PostPosted: Fri Apr 23, 2021 6:44 am    Post subject: Reply with quote
Hi
I didn't mean to degrade anyone's post. If it came across that way I apologize.
In our country, the saying is once shown is better than 20 times explained.
I'm not offensive or catchy. I meet a lot of different people and try to get along with everyone.
MWS I appreciate your knowledge and I will not reply anywhere you admit to it,so Mark doesn't have to delete posts.
Have a nice day
PostPosted: Fri Apr 23, 2021 7:33 am    Post subject: Reply with quote
SZTRAD, I do not have qualms against you, imho you are a knowledgeable member and I appreciate your posts.
Your intention of showing the effect of limited accuracy with Single was laudable, but it would have been laudable already by itself, there was no need to use other members efforts (yes, I put efforts in my posts, trying always to be technical correct) as an argument in the very sense of: 'Nice try guys, but now that's me, I'll explain it to the TO so he understands'.
And while I'm (most times) technical correct, I do miss any heightened level of courtesy, I am more the guy of telling it clear, pointed and direct.
If this annoys some members, my apologies, but I won't step back from this beloved behavior, thus it likely will happen again.
Be assured, it is never meant as harsh and personal as it may sound.
enniom
PostPosted: Fri Apr 23, 2021 4:57 pm    Post subject: Reply with quote
My Lord,
A Kumbaya moment to be memorialized in the annals of the BASCOM Forum.
E
PostPosted: Fri Apr 23, 2021 5:59 pm    Post subject: Reply with quote
enniom wrote:
A Kumbaya moment
Very Happy
PostPosted: Fri Apr 23, 2021 6:23 pm    Post subject: Reply with quote
I had to search for a while to find out what Ennion meant
Paroles de la chanson Kumbaya par Joan Baez
Kumbaya, my Lord, kumbaya
Oh, Lord, kumbaya
my poor lord !
yes sometimes our friends are a bit dry with their direct comments
but that is the charm of this forum
I had the same problem with the "singles" I had done the calculations on an Excel sheet and the results were very different when I redid the calculations with Bascom
then I discovered the doubles
Razz
Have a nice Week-end
JP Wink
AdrianJ
PostPosted: Sat Apr 24, 2021 2:07 am    Post subject: Reply with quote
Floating point always has rounding errors. Doing calcs in double precision is one way, but it really only masks the problem by pushing it down several decimal places, at the expense of very much longer execution time.. Where you only want the precision that singles can give, then using the Format statement on your result will give the nearest correct output display, regardless of the internal representation. "Real World" mearurements like readings from sensors are only very rarely accurate to more that a few decimal places, so it makes sense to use singles on these, and Format appropriately, rather than doubles.
Excel on a 64 bit machine allows 64 bits of precision, or 2^64, approx 10^20, or 20 digits of precision in decimal integers. I suspect that it uses this for almost all calcs for speed reasons, and only switches to floating point when necesary. ( And of course the machine it runs on also has a FP processor, so can drastically cut the execution time anyway )
Adrian Jansen
Goto page 1, 2  Next
Page 1 of 2
