chinas the clone of the classic '51
Goto page 1, 2, 3, 4  Next
Post new topic   Reply to topic    www.mcselec.com Forum Index -> BASCOM-8051
Alexander-Dan
PostPosted: Thu Apr 08, 2021 10:01 am    Post subject: chinas the clone of the classic '51 Reply with quote
hello!
accidentally found some very cheap microcontrollers in china.
A clone of the classic 51:
integrated bootloader, usb support, accelerated version. Minimal changes in register bits.
Has anyone tried these products? i'm very curious!
http://www.wch-ic.com/products/category/5.html - series 55x
http://www.wch-ic.com/products/CH552.html
http://www.wch-ic.com/products/CH551.html
SZTRAD
PostPosted: Thu Apr 08, 2021 11:26 am    Post subject: Reply with quote
Yes, I have.
What do you need to know?
The manufacturer is quite well known for making improved copies of the STM32.
I'm just afraid we won't understand each other linguistically.
RS
Alexander-Dan
PostPosted: Thu Apr 08, 2021 12:46 pm    Post subject: Reply with quote
SZTRAD wrote:
Yes, I have.
wow! Thank you for your reply!
do you have documentation in English for the '51 series products of this company?
is used WCHISPTool for downloading? Is it done via usb?
these uC are very difficult for me... C/C++ I don't know. It's Worse than 80x486 assembler Shocked
RS
google or other message translation software can help us: www.deepl.com/translator
it has not been a problem for the last 5-8 years.
I communicate with people from different countries: Poles, Bulgarians, Serbs, Germans, Dutch, Americans and Chinese.
SZTRAD
PostPosted: Thu Apr 08, 2021 3:04 pm    Post subject: Reply with quote
Hello,
Chinese-only manual and run it through the translator.
The links I send are in multiple versions. Yes uses USB. There is already an implementation of so kernel arduina. I send links for study.
I don't know what you're hoping for, I got it tested and found out it worked, but the manufacturer's support is practically none put it off, but if you insist on the 8051 core you'll look at the silabs.
He has more support and is in a normal language for us. I don't want to offend my fellow Japanese who is here, but for us Europeans it's indecipherable. Smile
Promised links
https://hackaday.io/project/169671-ch552-dragon
https://github.com/DeqingSun/ch55xduino
https://github.com/Blinkinlabs/ch554_sdcc
RS
Alexander-Dan
PostPosted: Thu Apr 08, 2021 3:31 pm    Post subject: Reply with quote
SZTRAD wrote:
Hello,
oh! Rolling Eyes
is a good warning. Yes, it is more reliable to use products from reputable companies!
I wanted to buy some of these products just because of interest. For my work the AVR is enough
Promised links
RS
thanks!
plouf
PostPosted: Thu Apr 08, 2021 6:23 pm    Post subject: Reply with quote
how "cheap" is cheap ?
SZTRAD
PostPosted: Fri Apr 09, 2021 8:04 am    Post subject: Reply with quote
Hi
These chips are also produced.
http://www.stcmicro.com/stc/stc51.html
Support is better drivers are also in Keil. And they have manuals in English.
There was one company, but I can't find samples and notes. But I suppose these clones Mark will never add so translators.
I can't imagine what would be good these days. The silabs on the other side are still making them, so I guess there will be an outlet.
So if you want to play, go ahead. If I hadn't been called in for tests, I wouldn't be playing.
RS
SZTRAD
PostPosted: Thu May 06, 2021 12:12 pm    Post subject: Reply with quote
Hi
I knew there was another company that makes "clones" of the 8051.
Coincidentally I have now been commissioned to test one product and there is an IO N76E003AT20 used. Which is an alternative (almost to the 89C4052) with more memory etc. It is made, like many other "aperture" products, by Nuvoton. The price is also interesting.
https://direct.nuvoton.com/en/8051-all-series/
Just for info if you ever get bored and want to play around.
It is used in this product for example
https://pl.aliexpress.com/item/1005001706122431.html?spm=a2g0o.productlist.0.0.14a831cbrDGSFZ&algo_pvid=34e763cc-3b52-468d-b8c4-78b17203eeea&algo_expid=34e763cc-3b52-468d-b8c4-78b17203eeea-19&btsid=0b0a555a16202993376258136ef69e&ws_ab_test=searchweb0_0,searchweb201602_,searchweb201603_
RS
Alexander-Dan
PostPosted: Thu May 06, 2021 12:34 pm    Post subject: Reply with quote
hi
Yes, I know about Nuvoton: they are developing clones of various uC families.
Thank you.
(Dziękuję Ci!)
Alexander-Dan
PostPosted: Sat Jan 06, 2024 10:29 am    Post subject: Reply with quote
Hello,
I tried several options for microcontrollers compatible with i51.
In the end, I followed your advice and chose chips STC:D
First impressions are very pleasant. (except that the support team did not respond to any of my emails).
I was able to make a dat file for the stc-8H in Bascom. And it works.
There are several oddities: for example, the Print and Input commands do not work.
I applied the disassembler, I see the use of other bits, so the commands are not working correctly. I wrote my own subroutine to work with UART1 and 2.
I’m gradually mastering the rest: I plan to use ADC and Timers.
If anyone is interested in this, I’ll post my work.
To load the program into the microcontroller I use stc-isp-v6.92I.exe
plouf
PostPosted: Sat Jan 06, 2024 10:19 pm    Post subject: Reply with quote
Amazing chips... Really
Worth take a look sometime i see them as low as 0,3eur + ship !! With 8k rom!
Chinese companies have this drawback. Hardly reply to hobbyst/small/outside china
Which is shame...
Nice works thanks a lot
Christos
Alexander-Dan
PostPosted: Sun Jan 07, 2024 7:56 am    Post subject: Reply with quote
I think if we are interested in purchasing volumes, then I will be able to communicate with this manufacturer: I have constant 3-4 contacts with Chinese suppliers.
I also have several agents in China, they work with all countries.
PostPosted: Tue Jan 09, 2024 11:14 am    Post subject: Reply with quote
thanks for the info and sharing.
i will implement it in BasCom-8051.
I must have a STC chip but i am not sure if it is the same. will check that.
otherwise i contact you for testing.
plouf
PostPosted: Tue Jan 09, 2024 12:09 pm    Post subject: Reply with quote
implementation means (almost) full working ?
i.e SPI / i2C / 2x UART / ADC etc ?
saying because alexander said that in his dat some of them do no work ..
sending chip's is the easiest Smile, i will order some to test only for the sake of quriosity.. only 0.3 with 8k adc etc (and 17kbyte at 0.33) !?
Christos
Alexander-Dan
PostPosted: Thu Jan 11, 2024 8:48 pm    Post subject: Reply with quote
greetings to all!
I apologize for the silence: I was on a trip, visiting relatives in my hometown (about 650 km from my new place of residence)...
At the moment, only what I indicated in my examples has been tested.
I hope to do more tests on the Bascom-51 and these chips over the course of this month and next.
Post new topic   Reply to topic    www.mcselec.com Forum Index -> BASCOM-8051 All times are GMT + 1 Hour
Page 1 of 4
