Question of 'AN #118 - I2C LCD and Keboard library'
O-Family
PostPosted: Sat Mar 20, 2021 1:19 am    Post subject: Question of 'AN #118 - I2C LCD and Keboard library' Reply with quote
Don't you think the initialization signal is strange for the I2C LCD library using PCF8574?
Is this a phenomenon only for my hardware?
The output result is different from the parameter of "Lcd_i2c.lib".
There is also a difference in the initialization of the LCD controller HD44780 data sheet.
O-Family
PostPosted: Tue Mar 23, 2021 4:07 am    Post subject: Reply with quote
In 'lcd_i2c.LIB'.
The '* BASIC: waitms 4' line seems to corrupt the contents of the variable '_temp1'.
I think that some LCDs may fail to initialize.
Also, is register R24 and variable '_temp1' overlaid in the '_write_lcd_byte:' routine?
I don't understand that '_temp1' is restored when pop R24.
laborratte
PostPosted: Tue Mar 23, 2021 11:53 am    Post subject: Reply with quote
comparing your measurements and the code _temp1 is clearly an alias for R24 or R25. As R24 and R25 are used and changed in *BASIC: waitms 4, _temp1 has the value of &h00 after waitms, that is corresponding to you measurement.
I would suggest a bugfix by adding a additional Ldi _temp1, &h03 like:
[_Init_LCD]
_Init_LCD:
 *BASIC: waitms 50
 ldi r16,&hc0       ; this is to make the initialization on both halfs of a 4-line LCD
 Ldi _temp1, &h03   ; at init-time I call all routines before _lcd_e is loaded into r16
 Rcall _Send_to_LCD
 *BASIC: waitms 4
 Ldi _temp1, &h03   ; reset _temp1 with the value as it is deleted in waitms
 Rcall _Send_to_LCD
 Rcall _Send_to_LCD
O-Family
PostPosted: Wed Mar 24, 2021 2:49 am    Post subject: Reply with quote
Thank you for checking.
I think the fix will improve it too.
Also,'bl_lcd_i2c.LIB' with backlight control has the same bug.
We are currently editing a new library to include additional features.
Paulvk
PostPosted: Wed Mar 24, 2021 9:50 am    Post subject: Reply with quote
It would have been nice to have an I2C library using two PCF8574s for the basic graphic displays these use a lot of pins.
The bugs may explain some of the intermittent odd things I have experienced.
Regards Paul
O-Family
PostPosted: Wed Mar 24, 2021 2:29 pm    Post subject: Reply with quote
I think the graphic LCD is possible with this MCP23017 board.
SZTRAD
PostPosted: Wed Mar 24, 2021 4:20 pm    Post subject: Reply with quote
Yes, it is.
The standard alphanumeric LCD is usable in this configurationwithout any problem.
Refresh for graphic is at the level of standard I2C graphic display.
RS
PostPosted: Wed Mar 24, 2021 8:53 pm    Post subject: Reply with quote
instead of using waitms you can use waitUS , of course adjusting the value a factor 1000.
waitus does not trash regs.
