Simulating XMEGA ADC
syndetic1
PostPosted: Sat Feb 27, 2021 4:06 am    Post subject: Simulating XMEGA ADC Reply with quote
The essence of this question is:
Does the simulator work with the XMEGA ADC?
Below is the code from
"C:\MCS\BASCAVR2083\Samples\XMEGA\ADC\xm128-ADC.bas"
In the listing below I only added $sim
The screen grab blow shows the simulation output. The output of every channel is always zero even though on the simulator, I set the ADC to a non zero value.
If it does work, can you explain what I am doing wrong and what I need to do to get it to simulate the ADC?
'                  (c) 1995-2020, MCS
'                      xm128-ADC.bas
'  This sample demonstrates the Xmega128A1 ADC
$regfile = "xm128a1def.dat"
$crystal = 32000000
$hwstack = 64
$swstack = 64
$framesize = 64
$sim
'configure the systemclock
Print "ADC test"
'setup the ADC-A converter
Config Adca = Single , Convmode = Unsigned , Resolution = 12bit , Dma = Off , Reference = Int1v , Event_mode = None , Prescaler = 32 , Ch0_gain = 1 , Ch0_inp = Single_ended , Mux0 = &B000_00 , _
Ch1_gain = 1 , Ch1_inp = Single_ended , Mux1 = &B1_000 , Ch2_gain = 1 , Ch2_inp = Single_ended , Mux2 = &B10_000 , Ch3_gain = 1 , Ch3_inp = Single_ended , Mux3 = &B11_000
Dim W As Word , I As Byte , Mux As Byte
  Mux = I * 8                                               ' or you can use shift left,3 to get the proper offset
  W = Getadc(adca , 0 , Mux)
  '   W = Getadc(adca , 0)                                     'when not using the MUX parameter the last value of the MUX will be used!
  ' use ADCA , use channel 0, and use the pinA.0-pinA.3
  Print "RES:" ; I ; "-" ; W
  Incr I
  If I > 3 Then I = 0
  Waitms 500
Loop Until Inkey(#1) = 27
end 'end program
enniom
PostPosted: Sat Feb 27, 2021 2:44 pm    Post subject: Reply with quote
Which input is the simulator expecting versus the code?
syndetic1
PostPosted: Sat Feb 27, 2021 6:04 pm    Post subject: Reply with quote
The simulator only allows you to set values for inputs 0-7.
I set all of the 8 simulator settings to non zero values.
I think Getadc(adca , 0 , Mux) where Mux = 0 should give me analogue input 0 ie PA0.
PostPosted: Sun Feb 28, 2021 11:23 am    Post subject: Reply with quote
Simulation of the ADC of the Xmega is not supported.
syndetic1
PostPosted: Sun Feb 28, 2021 9:01 pm    Post subject: Solved - Thank you Reply with quote
Thanks Mark for clarifying
