Timer1 interrupt won't fire
MadAl
PostPosted: Mon Dec 21, 2020 5:49 pm    Post subject: Timer1 interrupt won't fire Reply with quote
the following bit of code wont fire the interrup (ISR). What could be wrong?
Note that the timer is running as I can get a pulse on the OC1A port. Also the led works if I enable it in the DO-LOOP
$regfile = "m328pdef.dat"                                   ' specify the used micro
$crystal = 11059200
$baud = 115200
$hwstack = 256
$swstack = 256
$framesize = 256
Led_red Alias Portc.5
Config Led_red = Output
Reset Led_red
Config Timer1 = Timer , Prescale = 1024 , Compare_a = Disconnect , Compare_b = Disconnect , Clear_timer = 1
Compare1a = 5399
On Compare1a Timer1_isr Nosave
Enable Compare1a
    Waitms 500
'   Toggle Led_red
Timer1_isr:
   Toggle Led_red
thanks for a hint to get this going.
TW
PostPosted: Mon Dec 21, 2020 6:11 pm    Post subject: Reply with quote
Enable interrupts?
Thomas
laborratte
PostPosted: Mon Dec 21, 2020 6:25 pm    Post subject: Reply with quote
...and don't use nosave in on interrupt statement whem using isr like you do.
MadAl
PostPosted: Mon Dec 21, 2020 6:32 pm    Post subject: Reply with quote
Thanks,
I removed 'nosave' and the interrupt was already enabled by 'enable compare1a' . I tried replacing it by 'enable interrupts'.
No result.....
PostPosted: Mon Dec 21, 2020 6:45 pm    Post subject: Reply with quote
No replacing, you need them both.
MadAl
PostPosted: Mon Dec 21, 2020 6:49 pm    Post subject: Reply with quote
OK, so both 'enable compare1a' as well as 'enable interrupts' must be used I just found out. I was under the presumption that 'enable compare1a' would enable that particular interrupt. Not so.
Thanks for pointing that out!
PostPosted: Mon Dec 21, 2020 6:56 pm    Post subject: Reply with quote
Right so. The particular interrupt needs to be enabled and 'Enable Interrupts" additionally.
The latter is a global switch, affects the I-flag in the processor's status register, called SReg.
PostPosted: Tue Dec 29, 2020 1:37 pm    Post subject: Reply with quote
you best read the help topic about ENABLE and also ON INTERRUPT
you could say that the individual hardware interrupt on/off enable/disable switches form an AND gate with SREG-I , the master switch.
also note that the interrupt flags will be set regardless if an interrupt is enabled/disabled. the enable will only cause the call of the sub routine.
